Originally Posted by G_Raw
Be fore warned these are the FJ ones...don't believe me... read the top right corner. The none threaded section is longer than the Tacoma hub studs. The cone washes they sell also FJ's. You can get by with both of these but will break due to the above reasons if wheeling hard. If you're the overland type you should be good to go. Just carry a couple spares to swap if need be.
solid axle pickups used
4232360010 WASHER, CONE (FOR FRONT AXLE SHAFT),RH/LH
9011608325 BOLT, STUD (FOR FRONT AXLE OUTER SHAFT FLANGE),RH/LH
1st gen taco part number
9011608383 BOLT, STUD (FOR FRONT AXLE OUTER SHAFT FLANGE),RH/LH
Supersession(s): 90080-11282;
so yea the studs are different but toyota parts diag show the cone washer are the same. as far as I can tell. I have compared the studs side by side and the difference is like <1mm so it's not a huge deal IMO.
the taco ones just don't exist anymore, I have looked a couple of times and they just don't make them.
Trail-Gear ARP 2000 Hub Stud Kit if you really want to beef it up.
