11-20-2021, 12:29 PM
Do sequoia spindles fit?
I had a friend part out a 2wd 2002 Sequoia with less than 90k miles and I ended up with the front suspension pieces for free. Pretty sure my front wheel bearing are starting to grumble and get loud so I was wondering if anyone knew if the Sequoia spindles I have are the same or compatible as the 4runner? It would be much easier for me to just swap both spindles than deal with pressing bearings on and off
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
11-20-2021, 01:51 PM
Real Name: Patrick
Real Name: Patrick
I'm 99 percent sure they do not interchange. Sequoia spindles would be closer to Tundra spindles than 4Runners.
EDIT: I'm wrong. Learn something new every day!
11-20-2021, 02:01 PM
Real Name: Evan
Real Name: Evan
I was going to say the opposite. I think they’re all the same, as well as the front diffs. I believe the a arms, tie rods and ball joints are what’s different.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
11-20-2021, 02:13 PM
Real Name: Evan
Real Name: Evan
Spindle gussets from various manufacturers all show that they fit Tacoma, 4Runner and Tundra of similar years. Solo Motorsports has fabricated spindles that say they fit all 3 also, which would imply that there are no differences.
Toyota Full Fabricated Spindles - Solo Motorsports
11-20-2021, 07:53 PM
I thought the same thing and these exact reasons are why I asked. I didn't want to tear it all down to find out it's off by 10mm in some critical area and screws up alignment
11-21-2021, 04:14 AM
for 1999-2002 Tundra,the part numbers are the same as those of the 4Runner, after that the part numbers are different:
LH - 43202-35070/71 (ABS)
RH - 43201-35080/81 (ABS)
dunno why they changed part numbers. perhaps the newer ones are Made in the USA?
11-22-2021, 09:45 AM
Real Name: Patrick
Real Name: Patrick
Well that's good to know. I wonder if the bearings are the same and you can use the entire spindle minus the lower ball joint?
11-22-2021, 10:01 AM
only the 2001-2002 Tundra front axle hub bearings are the same as those of the 1996-2002 4Runner
11-24-2021, 12:20 AM
Well damn, i appreciate eveeryones replys but i was wrong and the sequoia was an '05 🙄. Anyone know what is different about them?
11-24-2021, 12:27 AM
Real Name: Devan
Real Name: Devan
Damn, read this thread in it's beginning and was also hoping this was the case. Why Toyota didn't just offer bolt on hubs is beyond me, life would be so much easier that way
11-24-2021, 12:29 AM
Real Name: Evan
Real Name: Evan
First gen Sequoia is up to 2007, so those should be the same spindle too.
