Old 12-05-2021, 12:55 PM #31
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Originally Posted by cl4Rk View Post
Ok took some measurements.
This was with a half tank of gas, full size spare in stock location, and about 30-50 pounds of tools in the back, roughly evenly distributed. New poly body mount bushings (no body lift).
The ground looked pretty level, about as level as I could find. It was in a CVS parking lot on an extra level looking row of handicap spots.
The lift only has about 200 miles on it, so I’m sure things will continue to settle a little bit.
Measured from center hubs to the bottom edge of my oversized fender flares:
FRONT DRIVER: ~ 21 1/16”
FRONT PASSENGER: ~ 21 1/4”
REAR DRIVER: ~ 22 1/4”
REAR PASSENGER: ~ 22 1/4”
So, the front driver side lean is just a little less than a 1/4”.
Rear side to side is level.
Once everything is done settling, I might add a 5mm trim packer to the driver front. (I should have done the trim packer with the initial install. Oh well.)
Thanks for those measurements & explaining how you took your measurements, makes a big difference for comparison consistency. I recently purchased 880/bilstein 24-248730 & 906/bilstein 24-249966 for my 2001. Assuming the information on Cruiser Outfitters is correct, 880 & 881 have the spring rate & bar diameter but 881 free height is 10mm taller than 880. Since OME rear springs (906, 890, 891, 861) are side specific with a 10mm height difference, I was thinking about experimenting with 881 on the driver side & 880 on the passenger instead of using different perch settings or spacer.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
bilstein , lift , ride , shocks , springs
2015 TRDP Shocks, OME Old Man Emu Shocks, Sway-a-way Rear Springs - Central MO - $350 Ammomac For Sale: Suspension/Wheels/Tires 0 09-07-2018 04:43 PM
FS: 5th Gen (2016 Trail) Front Coilover Shocks & Rear Shocks/Springs $175, West LA rgoodman00 For Sale: Suspension/Wheels/Tires 3 01-28-2016 03:22 PM
FS: FJ Swap Stuff Shocks Springs and More Shocks! Boulder, CO DonP4Runner For Sale: Suspension/Wheels/Tires 13 02-18-2015 09:42 AM
: 3rd G FS99 Tall Springs F+R and Front Shocks, 4R Wheels and tires, 97 springs SoCal mydogsmonkey For Sale: Suspension/Wheels/Tires 1 07-11-2014 10:36 AM
'99 front springs/shocks w/spacer & rear springs Full_Throttle For Sale: Suspension/Wheels/Tires 10 09-18-2012 11:57 PM
