Old 11-21-2021, 07:05 PM #1
fathousecat_ fathousecat_ is offline
fathousecat_ is on a distinguished road
Block Heater
Hello,
I am looking to install a block heater for the 5vz-fe. I see Katt's are out of stock. What are some other good options?
Thanks!
fathousecat_ is offline   Reply With QuoteReply With Quote
Old 11-22-2021, 11:48 AM #2
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Try Toyota part number C0140-02134
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 11-22-2021, 02:06 PM #3
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Originally Posted by fathousecat_ View Post
Hello,
Thanks!
I vastly (no, seriously, *VASTLY*) prefer a coolant heater to a "block" or oil heater. I've run a 'zerostart' brand for 17 years without failure or issue. Plugged it into a timer so that roughly an hour before first use it'd come on and heat. Worked amazingly, even down to -40.
Amazon.com: Zerostart 3309043 Circulation Tank Heater for Power Generation, Compressors, Agriculture, 3/4" Diameter Inlet/Outlet | cCSAus Approved and cULus Listed | 120 Volts | 1500 Watts : Automotive
That's basically the unit I ran, and yes there's some plumbing work involved, though there are some styles that replace a small section of the lower rad hose.
Having grown up in Wyoming with the other typical block heaters, I'll never go back to them.
That's basically the unit I ran.
Brian. is offline   Reply With QuoteReply With Quote
Old 11-26-2021, 11:03 AM #4
Thanks for this. Out here in Eastern MT we get -30s for a straight month atleast.
Old 11-26-2021, 11:16 AM #5
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
having used the "Katz" brand and the toyota one, the toyota one is better.. Easier to install ( the bend is tighter so it goes in easier) and the anchor bar is better.
that said , they can go bad, and they can develop a leak with age...either brand.
Old 11-26-2021, 12:05 PM #6
Brian.'s Avatar
Brian.'s Avatar
I know all about that. Born/raised in Wyoming, college at MSU Bozeman (met friends from out on the eastern side of the state), folks retired to White Sulphur Springs, MT. The beauty of the coolant heater was that you had instant Cabin heat too... just don't leave your radiator open/uncovered or you'll dump all that heat in an instant.
Old 11-26-2021, 12:38 PM #7
fatherdoug's Avatar
fatherdoug fatherdoug is offline
fatherdoug is on a distinguished road
fatherdoug's Avatar
I have them on the 4runners, but have never used them. Yes, I also live in Eastern Montana. I think -32F is the lowest I have seen here. The engine just took a couple more times to turn over.
My other 4Runner is a ford
fatherdoug is offline   Reply With QuoteReply With Quote
Old 11-26-2021, 01:31 PM #8
Not such a small world after all.
Old 04-22-2023, 02:17 PM #9
Real Name: 3 Bears
Real Name: 3 Bears
anyone know the current TOYOTA block heater number the C0140-01234 is not available....or I cant find it. This is my 3rd 3rd gen up here in alaska. First had the toyota, 2nd had the katz brand, it was a leaker, my current one has a toyota one in it, prob since new, but it is leaking. would prefer to get the toyota one. the fit better and easier to install.
local dealer is a joke.
also pyro2134
thanks
Old 04-22-2023, 05:23 PM #10
This place lists it but don't say if they have stock.
C014002134 - Toyota Heater, Block | Scarborough Toyota of Canada, Scarborough Ontario
There isn't an o-ring that you can replace?
Old 04-22-2023, 10:51 PM #11
Real Name: 3 Bears
Real Name: 3 Bears
thanks for the link..will see where it goes...all my normal sources...camel back, mcgeorge..aryama say not available...maybe I need a canadian source since thats where they originally came from for the toyota...a canadian manufacture unit.
no its leaking at a casting point....where the wire plugs into the unit. when I bought this rig almost 2 years ago now....it had green prestone type antifreeze...flushed and swapped out about a week after I got it
now im looking at about 4 months of weather above freezing so want to fix it...only looses about a few ounces every 2 tanks of gas. my former 2001 ( yuck) had a katz that leaked at the o ring between it and the block.
could not figure where my toyota antifreeze was going the past few weeks...until I did an oil change...the block heater is placed just above oil filter...i imagine...that the little it was seeping hit the hot oil filter...evaporated and never hit the ground..thats why I never saw antifreeze on the ground...in the snow...oil filter had a nice coating of dried antfreeze
block , good , heater , options , stock
Anyone use a block heater? gm350reratliff 4th Gen T4Rs 20 11-26-2020 11:08 AM
Who has a block heater LandCruiser 5th gen T4Rs 26 05-30-2016 09:36 PM
block heater typack Toronto / Ottawa / Ontario 13 05-09-2010 10:35 PM
3rd gen block heater? Qyota 3rd gen T4Rs 6 12-04-2009 11:43 AM
