11-23-2021, 11:59 AM
Real Name: Zack
Real Name: Zack
Broken down rope tow help
So I need to tow my 96 automatic 4wd home about two miles, can I rope tow that in neutral without messing anything up or do I need to get a flatbed? Thanks
11-23-2021, 12:01 PM
Two miles won't hurt anything.
But before you get going, try those brakes. The mechanical braking ability on a 4Runner without vacuum assist is pretty dismal. Get ready to MASH on the pedal to stop.
11-23-2021, 12:14 PM
Real Name: Zack
Real Name: Zack
So you’re saying it’s possible haha. But the breaks will work but really gonna have to press them?
i always tell the person being towed that THEY are the brakes, so when it's time to slow down, I use a hand signal and let them slow us down. It works fine to slow you down IF you let the towed vehicle start braking WAYYYY early, you really don't need a ton of pedal pressure even without power assist. Ideally you won't be going over 30 mph on a tow strap....
The 4Runner Show
11-23-2021, 12:20 PM
Yeah, I'm just warning to give it a try once or twice before you need to stop. It's a lot more effort than you'd expect.
I had a sticky one-way valve on the brake booster in mine - in really cold weather it would stick shut and I'd lose vac assist on the brakes. It's enough to catch you off guard.
11-23-2021, 01:17 PM
Originally Posted by shadow247
i always tell the person being towed that they are the brakes, so when it's time to slow down, i use a hand signal and let them slow us down. It works fine to slow you down if you let the towed vehicle start braking wayyyy early, you really don't need a ton of pedal pressure even without power assist. Ideally you won't be going over 30 mph on a tow strap....
^^^this^^^
'97 SR5 V6 4x4 | 5-speed | e-locker | 33's
11-23-2021, 03:00 PM
Transmission in neutral, transfer case in 4HI 2HI, go slow. Long tows are a big no-no since the transfer case will be un-lubed during the drive while flat towed in neutral.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
11-23-2021, 11:44 PM
Originally Posted by phattyduck
Transmission in neutral, transfer case in 4HI, go slow. Long tows are a big no-no since the transfer case will be un-lubed during the drive while flat towed in neutral.
Out of curiosity what’s the idea for transfer case in 4hi?
11-29-2021, 08:39 PM
You don't want the front and rear drive linked in case you go around any corners. Transfer case in neutral still links the front and rear drive, though if you shift it after the truck is off, at least the ADD won't be engaged.
11-30-2021, 01:13 PM
Real Name: Patrick
Real Name: Patrick
I'm confused. Wouldn't transfer case in 4hi still have the front and rear driveshafts linked together?
11-30-2021, 05:47 PM
Dammit. That's my fault. I meant 2HI.... ugh. going back to edit now.
11-30-2021, 05:48 PM
Real Name: Patrick
Real Name: Patrick
LOL you confused the crap out of me
