Old 11-26-2021, 04:23 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Rear power windows struggle to close
My rear windows (back seats) will roll down with no issues, but if I try to make them go up they will slow to a stop before they are closed. If I run over some bumps and jostle them they will move up a little before stopping again. Rolling the window up an inch at a time is a pita
It doesn't matter if I'm using the master switch on the drivers door panel or the switch in the back. Aiding the motor by pulling up on the glass has little affect. I heard from a Toyota mechanic that you can fix this by slamming the door hard and it sometimes helps free up the window mechanism, but that hasn't had an affect.
Are there any fixes or are my rear window motors toast?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 11-26-2021, 04:34 PM #2
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Spray some WD-40 silicone stuff on the window trails so it lubricates the tracks. Keep spraying until the windows work smoothly. I do this to all my cars and results always come out great. This is the cheap fix until you start diagnosing the window motor if the WD-40 doesn't fix the problem.
2000 4Runner Limited 4x4 V6
Old 11-26-2021, 04:48 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Lube up the window channels with silicone spray while working the windows up and down. If that doesn't fix it then either your window motors are weak/worn or you are not getting enough current to the window motors.
Old 11-26-2021, 05:48 PM #4
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Friends don't let friends use WD-40 (unless they're displacing water from a distributor, in which case it's the right tool). Silicone... spray or paste, both work well, on the window tracks. Might also be some caked on grease on the regulator pivots (or rust/corrosion). Could be corrosion on the electrical leads leading to power loss and toasty wires.
Easy stuff, try the silicone first as no disassembly is needed. Then pop the door cards and check the regulator/motor/wiring if that doesn't fix it. Won't take but 20~30 minutes on the first door, and like 10 or less on the second.
Brian. is offline   Reply With QuoteReply With Quote
Old 11-27-2021, 06:48 AM #5
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Went back with some WD-40 since its all I had. Window goes up slowly now but it doesn't get stuck anymore. I noticed it was quite dirty in the window track, so I'll go back with some alcohol and give it a proper clean out before using silicone spray if I can find it in a store.
Old 11-27-2021, 10:40 AM #6
Ripper238's Avatar
Ripper238's Avatar
Saw someone use RainX and it worked well. Ether way clean the winnow track well and use silicone.
affect , door , rear , window , windows
Power locks, windows, rear hatch working intermittently Rob_E 5th gen T4Rs 3 01-20-2023 10:41 AM
Have: Crank Windows Want: Power windows 5VZ-FE Want to Buy/Trade 2 04-21-2020 04:20 PM
Smart Key - Open/Close Windows fxoffroad 5th gen T4Rs 18 04-22-2014 12:51 PM
Power windows, power door locks, sunroof, rear window ALL DEAD JAKE_S 3rd gen T4Rs 2 03-18-2009 12:30 PM
please help, power windows, sunroof, rear window problems.. cartire Problems & Warranty Issues 0 02-13-2008 09:48 AM
