Old 11-30-2021, 07:24 AM #16
CRB Racing CRB Racing is offline
CRB Racing has a spectacular aura about CRB Racing has a spectacular aura about
With an Automatic trans, I would definitely go with 4:88 over 4:56.
Mine is manual wit 35s. I went with 4:88 and am very happy. The engine is revving about 3000 at 70 mph.
CRB Racing is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 10:18 AM #17
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
4.56 gears better than 4.88 if used a lot on the freeway?
Just a thought before you go down the gearing rabbit hole, what is the condition of your spark plugs and is your transmission cable that is attached to the throttle body adjusted properly?
My 99 had issues initially when I bought it also. In fact I bought it cheap because it didn’t run well. Wouldn’t maintain gear going down the road and just struggle the high speed. The throttle cable wasn’t adjusted right, and the throttle only opened about 70%. The the trans cable was wrongly set. And the plugs were worn to about 3 times the gap they needed to be.
After I addressed those, 80 mph was a breeze. Make sure your at least 38 psi if on load E tires as that makes a huge difference on the interstate for me. I have a new set of load C Generals to try out here soon to see if that improves the situation.
You use your 4runner like I do. Not a daily, but it see lots of miles and action when we go. I’m on 265/75 E’s and 4.30’s running valvoline max life trans fluid. Not a speed demon, but certainly adequate. If it’s been a while since ATF change, drain that out to and refill. It’s surprising what fresh ATF does.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 10:22 AM #18
Romeo1's Avatar
Romeo1's Avatar
Also, don’t be scared to lock out that overdrive when needed. Sometimes climbing it’s just mandatory.
I know everyone hates downshifting, but it’s just part of life. You don’t notice it as much in newer cars for lots of reasons, but it’s still there.
Even my 1 ton Cummins diesel manual requires downshifting sometimes, and that thing is the no downshifting king.
Old 11-30-2021, 10:24 AM #19
Romeo1's Avatar
Romeo1's Avatar
Just out of curiosity @, you mentioned 285’s, what tires and load rating you running?
Old 11-30-2021, 11:03 AM #20
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
This right here. My truck pulls fine on the hilly backroads with OD off. I didn't notice any drop in MPG as it keeps a consistent RPM instead of constantly hunting for the sweet spot.
I only have to turn OD off when I'm loaded for camping. I recently upgrade to 4.30's with 265/70/16's, so I added about an inch of tire height over my old setup. The change is barely noticeable with the 4.30's. Definitely would be worth it to go to 4.88 if i was going up to a 33-35 inch tire.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 01:25 PM #21
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by thezentree View Post
I've had 4.56s and 285s for a couple years now and I still feel conflicted about my choice.
I spend a lot of time on the interstate too, which is why I chose 4.56s over 4.88s. I find myself dropping out of OD frequently to climb long hills. It's not as quick around town as it would be if it had 4.88s.
It also turns ~2500rpm at 75mph and gets close to 19mpg on the highway. I dunno. Really these things need 4.88s and a 5 speed w/ OD, not this goofy ass three speed transmission.
I think a 6 speed auto would be the sweet spot rather than the 4 speed autos we have. Technology wasn't around for that back then, but it sure would have been nice to have a lower first gear ratio, 2 overdrives, and a much wider gear ratio spread.
Old 11-30-2021, 03:05 PM #22
Option01 Option01 is offline
Option01 is on a distinguished road
Originally Posted by gamefreakgc View Post
A stock automatic 4Runner with 265/70/R16 tires has too tall of gears to begin with. It constantly wants to lug around in sub-2K RPM. The only reason why is that you can eek out a tiny, and I mean tiny, big more miles per gallon that way. I would argue that a stock auto should have come with 4.56 gears like some of the 2nd Gen 4Runners and 1st Gen pickups did. Also, the 5-speed and autos have very different transmission gear ratios so be careful comparing the two. The grimjeeper website mentioned above is very accurate and has the correct ratios.
Just remember, this is the 5VZ-FE engine we are talking about. It's not perfect by any means but one thing it is is overbuilt and very durable. Cruising at 2100 RPM or 2500 RPM isn't going to make much of a difference, if at all to the life of the engine. I am hopefully going to be putting 5.29 gears in my 4Runner with stock tires by the end of the year and will be cruising at 70 MPH at 2900 RPM.
First off, howdy neighbor! (I live in Fair Oaks)
Yeah, that's good advice about being careful regarding the 5-speed vs automatic. I think some of my early concerns about 4.88 came from old posts that were talking about 5-speeds and/or 4 cylinder motors. That's part of the reason I started a new thread: to try to get input specific for my vehicle/usage.
I think you're right about the stock gearing and almost wonder if the drivetrain was dialed in based on the base 28" wheel size even though most 3rd gens seems to have been sold with the 31" option. Or maybe it was done that way to help it score a little better fuel efficiency for the window sticker.
Wow, 5.29 on stock tires! That's going to be pretty aggressive. I assume you won't be using your 4Runner much on the freeway?
1999 SR5 V6/Auto 4WD
4.88 Gears, Front/Rear E-Lockers
1" Body Lift, 2" Suspension Lift, 285/75 R16 Tires
Option01 is offline   Reply With QuoteReply With Quote
Old 11-30-2021, 03:20 PM #23
Originally Posted by Cree View Post
4.88s would give you an effective ratio in the 4.30s. I'd do it.
Yeah, I guess you're right that the 33" tires combined with 4.88 gears is pretty close to the stock 31" tires with 4.30 gears. Compared to that stock setup, the 4.88 would be roughly 125 RPMs higher at 65mph (2300rpm) and the 4.56 would actually have run 25 RPMs lower (2154rpm).
Old 11-30-2021, 03:54 PM #24
Thanks for the excellent advice! I'm friends with the prior owner and we've both kept up with the maintenance so I assume it's running well. Plus, it only has 140k miles and the smog tests always come back super clean (the techs are usually surprised how clean) so I suspect that's another good sign about the state of the motor. However, I don't know that anyone has ever looked at the throttle cable so that might be worth checking out.
A big part of the reason for re-gearing is that I want to put lockers on the front and rear so it makes sense to do it all at once.
Regarding the tire pressure, I'm running Duratec 285/75R/16 which are LT rated and I'm not 100% sure what psi I should be running. The tire store put them at 35psi and that seems to be in the ballpark for what other people are doing based on some google searches.
Old 11-30-2021, 04:03 PM #25
Another good point. Maybe it's just unrealistic for me to expect a heavy truck to accelerate uphill in overdrive. It just currently feels like I'm stuck in 4th with no power unless I floor the gas pedal to get it to drop into 3rd at which point it jumps 800rpm and starts moving. It'd be nice if I could get away from those Jekyll/Hyde extremes.
Old 11-30-2021, 04:30 PM #26
Real Name: Patrick
Real Name: Patrick
I ALWAYS recommend that people with larger than OEM tires or higher capacity rated tires (LT or load range D/E/F) chalk test their tires to find the best psi for full engagement across the tread blocks. I've had customers complain of a rough ride in their light duty trucks (1500) that are running load range E tires at 80 psi. At that pressure with such little weight you will feel every crack in the road and have a terrible and small contact patch.
Old 11-30-2021, 04:32 PM #27
THANK YOU! I was really hoping to hear from some people who have the same drivetrain and had upgraded to either gear size.
Personally speaking, I'm not too worried about it being "quick around town" but its very interesting to hear that you're still dropping out of OD to climb long hills. I wonder if the extra 140-160rpms that the 4.88 gears would give at freeway speeds would allow you to stay in OD? If not, that might push me a bit closer to the 4.56 gears. My reasoning is that if I'm going to be running in 3rd gear the whole way up the mountain either way, I'd rather do it at 2800-3300rpm than 3000-3500rpm
Old 11-30-2021, 04:42 PM #28
That sounds like a really good idea. I suppose I should probably do the test unloaded as well as fully loaded to get appropriate pressures for each scenario?
Old 11-30-2021, 05:46 PM #29
Real Name: Patrick
Real Name: Patrick
It would probably be a good idea if your cargo or trailer tongue weight is a couple hundred pounds or more.
Old 11-30-2021, 07:05 PM #30
Cree's Avatar
Cree Cree is offline
Cree will become famous soon enough Cree will become famous soon enough
Cree's Avatar
Actually I'm wrong. I did my calculations off stock 15s. 4.88s would give you 4.55s on 285s. 4.56 would be a 4.25.
I use this site.... TireSize.com - Compare Tire Sizes, Specs, Prices & more
00 Limited - Stuff!
18 Audi A6 3.0T - APR Tuned, RS6 Interior
19 Audi A6 3.0T
Cree is offline   Reply With QuoteReply With Quote
freeway , gears , lot , tires , upgrade
Dana SVL vs. Revolution Gears vs. Nitro Gears VernySanders 3rd gen T4Rs 3 02-29-2024 02:39 PM
Help me decide between Sonoransteel 1.2 or 7.2 lift, 33 vs 35's, gears or no gears??? 240m3srt 3rd gen T4Rs 19 11-14-2014 03:33 AM
3rd gen died on the freeway jplars 3rd gen T4Rs 4 10-19-2014 09:02 PM
r.p.m's on the freeway Forrrrest 3rd gen T4Rs 18 11-01-2012 12:41 AM
just died @ 65 on freeway.. MUDNBEER Problems & Warranty Issues 1 03-26-2011 10:31 PM
