Old 12-02-2021, 02:23 PM #46
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Originally Posted by Option01 View Post
I see now why so few people go with the 4.56 ratio. With such a flat torque curve, you really need to get those rpms up to generate more power.
Tell me about it! That's been my fight from day one. My engine makes plenty of torque (~400 at the crank) but the transmission wants to drop the RPM down really low and make very little power. The O/D button on the shifter is your friend, don't be afraid to just keep it off and let it turn at closer to 3000 RPM. Also, keep ECT Power on non-stop, every day. It does make a difference. That's essentially what I'm after with the regear, making 4th gear closer to 3rd. I made this graph a while back to visually represent each gear and the top speed of each. Look especially at how the 5-speed transmission is geared and how much more torque multiplication it has due to shorter gears. The red line is our speed governor.
326WHP 347TQ
Old 12-02-2021, 03:25 PM #47
Bad Luck Bad Luck is online now
Real Name: Patrick
Real Name: Patrick
That graph is awesome! What gearing is shown with the 5 speed transmission? What rpm's did you use for the top speed in each gear?
Bad Luck is online now   Reply With QuoteReply With Quote
Old 12-03-2021, 12:18 AM #48
Option01 Option01 is offline
Option01 is on a distinguished road
Awesome! Looks like the 5.29 ratio would give you something similar to the 5-speed without the overdrive gear. Would be interesting to hear from the 5-speed guys about how they'd feel driving without their fifth gear.
1999 SR5 V6/Auto 4WD
4.88 Gears, Front/Rear E-Lockers
1" Body Lift, 2" Suspension Lift, 285/75 R16 Tires
Option01 is offline   Reply With QuoteReply With Quote
Old 12-03-2021, 07:46 PM #49
Originally Posted by Romeo1 View Post
Just a thought before you go down the gearing rabbit hole, what is the condition of your spark plugs and is your transmission cable that is attached to the throttle body adjusted properly?
My 99 had issues initially when I bought it also. In fact I bought it cheap because it didn’t run well. Wouldn’t maintain gear going down the road and just struggle the high speed. The throttle cable wasn’t adjusted right, and the throttle only opened about 70%. The the trans cable was wrongly set. And the plugs were worn to about 3 times the gap they needed to be.
Wow, thanks again for this recommendation! I had some time to look under the hood today and sure enough, there was a good deal of slack in the throttle cable. It seems the rubber bushing where the cable connects to the accelerator petal was split/destroyed. I tightened the cable via the adjustment section near the throttle body but haven't had a chance to test it out on the road yet. Assuming everything runs okay, I'm now wondering if it's even worth the hassle of replacing the cable.
Old 12-03-2021, 10:52 PM #50
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Called it! Mine had the exact same problem. I adjusted it for now. I have a new cable sitting on the bench whenever I get around to it.
Seriously though. Healthy plugs, good wires, clean air filter, throttle body and trans cable adjusted right make all the difference in the world.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 12-04-2021, 04:11 PM #51
Real Name: Jerod
Real Name: Jerod
Oh, I forgot that part. It's 4.10 gears on the 5-speed. Max RPM is 5500. I realize that a 5-speed can rev higher but to keep the data consistent I used the auto redline limiter. There's absolutely no power above 5000 RPM when stock anyway.
326WHP 347TQ
Old 12-04-2021, 05:52 PM #52
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
If you are gonna bust the diffs open anyway go with the 4.88's.. and you can use a locker in the front as you said in the snow..just have to be mindful of slip.
Just repaired locked Tundra that split front diff w/ARB it was ugly!!
SaulG is offline   Reply With QuoteReply With Quote
Old 01-08-2022, 05:40 PM #53
So just a quick update. I dropped off the 4runner at the shop this morning and went with the 4.88 ratio. Thanks again to everyone who chimed in on this thread to share their suggestions and experiences. Now I just need to figure out how to properly break in the new gears in a short period of time!
freeway , gears , lot , tires , upgrade
Dana SVL vs. Revolution Gears vs. Nitro Gears VernySanders 3rd gen T4Rs 3 02-29-2024 02:39 PM
Help me decide between Sonoransteel 1.2 or 7.2 lift, 33 vs 35's, gears or no gears??? 240m3srt 3rd gen T4Rs 19 11-14-2014 03:33 AM
3rd gen died on the freeway jplars 3rd gen T4Rs 4 10-19-2014 09:02 PM
r.p.m's on the freeway Forrrrest 3rd gen T4Rs 18 11-01-2012 12:41 AM
just died @ 65 on freeway.. MUDNBEER Problems & Warranty Issues 1 03-26-2011 10:31 PM
