Old 01-15-2009, 02:10 AM #1
Matthew Starr's Avatar
Matthew Starr Matthew Starr is offline
Banned
Matthew Starr is on a distinguished road
Banned
Talking How to get better throttle response FOR FREE!
So i just figured this a couple hours ago, i was driving my company 2002 tacoma today and i noticed that the throttle response in my 4runner sucked compared to my company tacoma. So i stared at my throttle body for hours and reallized that you can adjust your throttle cable to make it tighter. after 9 years (on mine) my t-cable has stretched out a little. all you need is 2, 14mm wrenches and adjust your throttle body a little. i just thought id share that bit of info with you all.
Matthew Starr is offline   Reply With QuoteReply With Quote
Old 01-15-2009, 03:12 AM #2
Ohio4R Ohio4R is offline
Ohio4R is an unknown quantity at this point
post a picture of what bolts we need to tighten
Ohio4R is offline   Reply With QuoteReply With Quote
Old 01-15-2009, 04:27 AM #3
Clemsonfan15's Avatar
Clemsonfan15 Clemsonfan15 is offline
Clemsonfan15 will become famous soon enough
Hmm...Interesting. Any negatives to doing this?
If I'm on the interstate and press the petal all the way down sometimes it will be 2-3 seconds before it shifts into a lower gear and starts to really acclerate. I wonder if this would help solve the problem.
Check out my garage.
Clemsonfan15 is offline   Reply With QuoteReply With Quote
Old 01-15-2009, 04:31 AM #4
JC_ez JC_ez is offline
JC_ez is on a distinguished road
You can also bring the transmission kickdown (1996-2000 only) and cruise control cables back to spec by tightening the corresponding cables. Both cables are located on the throttle body as well.
I tightened all my cables so that there is no tension but no slack when everything is at rest
JC_ez is offline   Reply With QuoteReply With Quote
Old 01-15-2009, 07:13 PM #5
DewRunner's Avatar
DewRunner DewRunner is offline
DewRunner is on a distinguished road
DewRunner's Avatar
This should be in the minute mod!
i love it, so much better now! haha thanks man you rock!
96 4Runner SR5/TRD
DewRunner is offline   Reply With QuoteReply With Quote
Old 01-15-2009, 07:37 PM #6
CSL's Avatar
CSL CSL is offline
CSL is on a distinguished road
CSL CSL is offline
CSL's Avatar
Mathew, for us less-than-familar folks, take a photo and post it (as previously suggested) Thanks in advance
Current Rig: 1999 5Runner (customized 100 series LC)
Past Rig: 2000 Sport Edition -- Debadged -- Flares Removed -- 5 BFG AT's 265/75/R16 -- OME 882 & LC Coils -- SS Diff. Drop -- Dual Optima Batteries -- Tundra 199mm brakes
Custom Kitchen -- Cargo Door Light -- Enlarged Storage Compartment
CSL is offline   Reply With QuoteReply With Quote
Old 01-15-2009, 07:45 PM #7
DewRunner's Avatar
DewRunner's Avatar
Here you guys go.
just tighten the slack out of these three cables
nuts to tighten are circled hope this helps
96 4Runner SR5/TRD
Old 01-15-2009, 10:00 PM #8
Originally posted by DewRunner
Here you guys go.
To clarify this picture a bit more: The red circle to the left is the cruise control cable. The red circle to the upper right is the transmission kickdown cable. The red circle to the lower right is the accelerator cable. Tighten just enough to remove the slack, but not too tight. Also, cleaning the area (like the spring) from dirt helps too. I spray silicone on the spring and in the cable housings to help with smooth movement and to repel dirt from sticking.
Old 01-15-2009, 10:32 PM #9
move120's Avatar
move120 move120 is offline
move120 is an unknown quantity at this point
move120's Avatar
very interesting, i wonder if this answers my question as to why 01 and 02's are so much quicker to the pedal
2000 Toyota 4Runner Limited
move120 is offline   Reply With QuoteReply With Quote
Old 01-16-2009, 12:52 AM #10
Stick Figure's Avatar
Stick Figure Stick Figure is offline
Stick Figure will become famous soon enough
01 and 02 are drive by wire IIRC so they would be totally different situation.
Stick Figure is offline   Reply With QuoteReply With Quote
Old 01-16-2009, 01:08 AM #11
What is drive by wire?
Dew: What is that filter like thing?
Old 01-16-2009, 03:37 AM #12
Banned
Banned
Ok im sorry for not posting pics or more instructions. Thank you drew for the pic. heres some instructions for you all:
1. Throttle Cable
2. Trasmission kickdown cable
3. Cruise controll cable
Using 2, 14mm wrenches loosen the nut on the left of the 2 nuts (1,2) to the right of the 2 nuts (3) in the direction of the arrows. Then pull the cable tight and move the other nut over to hold the cable in place. It's better to do this with 2 people, have 1 person sit in the car and push on the gas pedal while the other person adjusts the cable. Doing this will allow the person adjusting the cable to see how much slack is still in the line. Adjusting the cable to tight will cause your throttle to be open a little bit, you will know if its too tight if you turn your car on and it idles at i higher rpm than normal. Adjusting the cable to loose will result in having to push the pedal all the way to the floor to get throttle response. Make sure to tighen all your cable nuts and ta da, throttle response.
Old 01-16-2009, 06:16 AM #13
Drive by wire is an electronically controlled throttle (no direct cable connection between pedal and throttle). The 2001-2002 do not have an adjustable kickdown cable (electronically controlled). I think they switched to a drive by wire system to have more electronic features like VSC.
Old 01-16-2009, 10:37 AM #14
CSL's Avatar
CSL CSL is offline
CSL CSL is offline
CSL's Avatar
Checked mine out this morning and all the cables are LOOSE! two of the cables are so loose that they are almost out of the little gutters they are supposed to sit in. I brought my wrenches with me today, and can't wait to adjust these at lunch time!
This could be good...
Old 01-16-2009, 12:01 PM #15
Thanks for the write up Matthew. I'm going to check mine today.
3.slow throttle response tip 88T4RE Classic T4Rs 2 01-04-2010 01:45 AM
No throttle response after head job Grimsta Problems & Warranty Issues 2 01-24-2008 12:29 PM
No throttle response after head job Grimsta Classic T4Rs 3 01-23-2008 06:07 PM
poor throttle response when cold 1990runner Classic T4Rs 0 12-09-2004 08:17 PM
Throttle Icing Thai Maintenance/Detailing 0 02-27-2003 05:44 PM
