Old 12-08-2021, 12:37 PM #31
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
I love my air lockers front and rear. I can't comment on TT or LSD's with a 4runner and how they compare to the airlockers. What I can say is that when maneuvering my front over tougher obstacles it is nice to have a selectable locker that I can turn on and off just to get through the event and not something that try to engage when I'm past the point of needing it. I wonder if a TT would still engage with enough torque transfer while clearing an obstacle that results in loss of wheel contact on one side and transfer torque to the contact side that would risk breaking the CV all during a point where that sort of traction control is no longer truly needed on the obstacle.
I say this because I have learned that while clearing a front obstacle while using my locker that it is crucial to maintain the foresight to turn it off once you don't need it's help anymore...even if you are still midway through the obstacle. This is because the torque transfer that occurs is rough on our front IFS Diffs and CV's. I have broken a couple front CV's due to not disengaging the locker in time.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 12-08-2021, 02:37 PM #32
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
I've read about this. Did you fit beefier CV axles to cope with the additional stress?
A lot of concerns over fitting front lockers is that the IFS cant handle the stress and has a tendency to get all snappy on the trails. I also read an ancient Motor Trend article that said its a good idea to upgrade the tie rod ends too. One thing to consider is that the larger your tires are, the more stress you'll be applying to your ifs.
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 12-08-2021, 02:38 PM #33
Originally Posted by JohnMc View Post
I will readily admit that I haven't wheeled with an LSD up front, but based on PURE IDLE SPECULATION (enough of a disclaimer?) I don't think it would be that ideal. LSD's only transmit significant traction to the loaded wheel when there's a bit of spin in the system. And with a locker in the rear and in 4WD, the only way you're going to get significant spin is if all 3 other tires are spinning, and only then will it transfer some torque to the front wheel with more grip than the unweighted one.
LSD options get even more complicated when you consider a Torque-sensing type (Torsen, or Trutrac) vs. clutch-type vs. viscous. Each type acts differently. Not that there many options for the 7.5" front, just a general comment that comes up more often in performance cars instead of off road trucks.
Your point about slipping sideways when both wheels spin is also important - it matters for both on-road low traction situations and off road off-camber situations.
My Alltrac Camry is a drift machine in the snow because it has a Torsen (like Trutrac) rear that basically stays locked in low traction situations. It was that way even when it only had 100hp - and now it has ~275hp. Fun, but you HAVE to know what you are doing and be ready for it.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-08-2021, 11:18 PM #34
G_Raw's Avatar
G_Raw's Avatar
I run FJ tie rods. I'm still running Napa aftermarkets lifetime warranty CV's and just wrecking my way through them no paying s dime after the first 3...a set and a trail spare... all has been good that route.Working my way to 35's and may consider some beefier CV's then however my manual hubs are an issue for all companies other than Lotus... and at $2400 for a set and spare of Lotus I'll probably go down the rabbit hole of SAS.
Old 04-26-2022, 07:21 PM #35
psea17 psea17 is offline
psea17 will become famous soon enough
Originally Posted by mtbtim View Post
Thanks for the info. I was thinking if I went with a front locker I'd go with a Harrop but now you got me thinking.
Timmy, was wondering if you had made a decision here or if your research had steered you in a particular direction. I'm considering a front locker now that i just secured a 4.3 rear axle w/ elocker along w/ the matching front diff.
psea
'98 4Run SR5 v6 4x4-Orig Owner
Manual Transmission
Bilstein 5100 (front/rear)
OME 890 Springs (rear)
'99 Tall Springs (front)
psea17 is offline   Reply With QuoteReply With Quote
Old 04-27-2022, 02:46 PM #36
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I've been running Harrop front 2 yrs. 10k mi how it operates has not been an issue yet.
On a 01 did E-locker rear swap wanted E-locker front, if it breaks, I'll deal with it just like ARB.
diff , front , gasket , limited , slip
Can I install a limited slip diff and still keep my e-locker? phx_4Runner 3rd gen T4Rs 22 08-19-2021 06:03 PM
2009 Limited V6 Muilti Mode 4wd Rear Diff not limited slip ? JCSTEW 4th Gen T4Rs 3 09-13-2015 10:00 PM
WTB: locking or limited slip differential for 02 SR5 RedbeardPete Want to Buy/Trade 0 03-16-2015 10:37 AM
Does TE rear diff have limited slip too? GreerAZ 5th gen T4Rs 1 07-31-2011 02:22 PM
Limited slip rear diff? M1911 4th Gen T4Rs 3 03-22-2011 07:36 PM
