Originally Posted by JohnMc
I will readily admit that I haven't wheeled with an LSD up front, but based on PURE IDLE SPECULATION (enough of a disclaimer?) I don't think it would be that ideal. LSD's only transmit significant traction to the loaded wheel when there's a bit of spin in the system. And with a locker in the rear and in 4WD, the only way you're going to get significant spin is if all 3 other tires are spinning, and only then will it transfer some torque to the front wheel with more grip than the unweighted one.
LSD options get even more complicated when you consider a Torque-sensing type (Torsen, or Trutrac) vs. clutch-type vs. viscous. Each type acts differently. Not that there many options for the 7.5" front, just a general comment that comes up more often in performance cars instead of off road trucks.
Your point about slipping sideways when both wheels spin is also important - it matters for both on-road low traction situations and off road off-camber situations.
My Alltrac Camry is a drift machine in the snow because it has a Torsen (like Trutrac) rear that basically stays locked in low traction situations. It was that way even when it only had 100hp - and now it has ~275hp. Fun, but you HAVE to know what you are doing and be ready for it.
'99 4Runner SR5 Auto -
4WD swapped
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
