Old 12-07-2021, 05:47 PM #1
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Marlin Crawler Dual Transfer Case Install (Parts 1 & 2)
Hey Dudes,
We finally have Part 2 live for the Marlin Crawler Dual Transfer Case Install. If you are interested in running dual cases, this video series can help your through the process.
Old 12-08-2021, 02:18 AM #2
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
the modifications just keep getting sicker folks
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 12-08-2021, 02:37 AM #3
busmup808's Avatar
busmup808 busmup808 is offline
busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough
busmup808's Avatar
I’ve been waiting for my MC09 case for a year now! I have the front adapter and 4.7 comp gears from Marlin
Busmup808 all day, all night!
busmup808 is offline   Reply With QuoteReply With Quote
Old 12-08-2021, 11:35 AM #4
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
The Crawler box (with optional 4.7 gears in the added reduction box) is certainly a better, more flexible solution. Even if the combined ~12:1 is a bit comically low.
At least I assumed it would mostly be a party trick, not actually useful on the trail. But this summer on a steep downhill ledge (Rose Garden Hill near Moab) my wife was able to just idle down in 1st gear (manual trans '96) and never needed to touch the brakes. So much gear multiplication going on that the truck just does whatever the engine is doing, pays practically no attention to the drivetrain load, pushing or pulling.
The availability of those gearboxes and the input shaft (turbo 1st gen?) made me go a different way on my '99. A Northwest Fabworks Ecocrawler kit. It uses the planetary reduction gears from a common as dirt 3rd gen transfer case. No waiting around for rare parts (my wife was lucky when she ordered her Marlin kit and got a built box with it). It's not quite as neat, however, since it will just have two different 2.57 reduction gears, so just a 3 speed transfer case (1, 2.57/2.57, and 6.6 combined) instead of a 4 speed (1, 2.57, 4.7, 12).
I haven't installed it yet, but it looks a little more involved than the Marlin install can be. On the Marlin kit, you can leave the original transfer case largely alone if you're not doing a triple stick as well. Taking that little 'pill' out that prevents 2LO means taking it apart a little bit.
JohnMc is offline   Reply With QuoteReply With Quote
Old 12-08-2021, 02:32 PM #5
vegask vegask is offline
vegask will become famous soon enough
Thats exactly how I would describe it. I have 4.7s on an auto and have yet to find a situation where its needed. My crawl box has also started to pop out of gear every now and then in the past 2 years.
Awesome videos, I wish they were around when I did mine.
SAS 97 4runner / Bone stock 2005 4runner / aka "Kurtfab"
vegask is offline   Reply With QuoteReply With Quote
Old 12-08-2021, 02:35 PM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Would you find a 2.57/2.57 combo rather than a 4.7/2.57 combo more suitable to an automatic?
Old 12-08-2021, 02:45 PM #7
If I were to do it again, I would probably have done it that way. But I got a really good deal on a set of 4.7s.
Old 12-08-2021, 07:41 PM #8
busmup808's Avatar
busmup808's Avatar
I really would of liked to go the route you went, but unfortunately I was deep into the Marlin parts 2years ago, compared to ordering the route you went and having it completed before the end of this year. I do have a 5spd from a 98 that I wanted to convert if the auto trans took a shit.
Old 12-08-2021, 08:34 PM #9
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
Once Tim runs out of videos to do I’m going to come out to California and we can do a video of me and Tim smoking pcp and searching for the Loch Ness monster
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 12-08-2021, 09:46 PM #10
theesotericone's Avatar
theesotericone theesotericone is offline
theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice theesotericone is just really nice
I'm auto with 2.28/2.57. It's perfect. The torque converter effectively doubles the crawl ratio. Math wise I'm 87:1 in lo/lo. Because of the torque converter it feels like 174:1. I've driven a buddies 1st Gen Taco with 4.5/2.57. In lo/lo and first gear I can't really tell the difference between his rig and mine.
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. --Albert Einstein
theesotericone is offline   Reply With QuoteReply With Quote
case , dual , install , marlin , transfer
Marlin Crawler Dual Transfer Case Assembly infamousRNR 3rd gen T4Rs 1 08-09-2021 02:09 PM
FS 3rd Gen Marlin Crawler transfer case adapter NEW!! PHX, AZ $360 joeynational For Sale: T4R Items 0 12-03-2019 10:35 AM
WTB Marlin Crawler TacoBox - 3rd Gen Chain T-Case Rimcrew For Sale: T4R Items 4 10-04-2018 08:44 AM
Marlin and Inchworm Transfer Case Help Northeast_T4R 4th Gen T4Rs 23 06-18-2010 04:10 AM
