Old 12-08-2021, 02:13 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
How do I change the clutch fluid? (W59)
I have a W59 manual transmission and I want to flush out the nasty looking DOT 3 brake fluid and put new fluid in. There are no videos on my particular transmission, and very few in general, my FSM is vague about flushing out the system.
Can I use this video for a 2011 Tacoma?
Where exactly should I bleed the fluid from?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 12-08-2021, 02:31 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Have you ever bled brakes before?
EDIT: I tried to watch the video but couldn't make it past 7 seconds.
Old 12-08-2021, 02:42 PM #3
Not much to it. Find the bleeder screw on the clutch slave cylinder - that's where the fluid will come out. Otherwise, it is just like bleeding brakes, but with the clutch pedal. You can use a pressure bleeder, vacuum bleeder or the two-person method. Even if you use the two person method, it is nice to have the auto-filler bottle from a vacuum bleeder to make sure the master cylinder stays full.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-09-2021, 02:06 PM #4
enginelover enginelover is offline
enginelover is on a distinguished road
As Charlie says, it's not different than bleeding the brakes.
I did it when I had to replace the (why is it pink?) slave cylinder though (because bleeding wasn't done enough prior to that failure point I guess).
You pour the fluid into any DOT3/4 brake fluid into the reservoir in the engine bay and with a helper pressing the pedal you give the command from below.... ready... press... release (where the helper doesn't release until you've closed the fitting).
Best if you have about an 18 inch length (or thereabouts) of clear plastic tubing to fit over the fitting and then into a jar where you're in such a contorted position it's best to just drill a hole in the top of a heavy jar that won't easily tip over. Also you will likely spill depending on how sloooooooooowly the helper pumps the pedal so put a few rags around the reservoir and instruct your helper to be "firm but gentle" with the pedal.
I have used pressure bleeders for other vehicles's brakes and found them to be more trouble than the helper usually is.
Also check the pedal return mechanism carefully as the springs are downright diabolical.
enginelover is offline   Reply With QuoteReply With Quote
Old 12-10-2021, 05:58 PM #5
tpdietz tpdietz is offline
tpdietz is on a distinguished road
Yep, like others have said it's the same as the brakes. You can make this a simple 5 minute job if you opt to install a speed bleeder
Speedbleeder for Clutch Slave?
1995 4Runner SR5 4spd
2000 4Runner SR5 5spd
2022 4Runner Special Trail Edition
tpdietz is offline   Reply With QuoteReply With Quote
Old 12-12-2021, 08:18 PM #6
cahilc cahilc is offline
cahilc is on a distinguished road
Prefer the Shade Tree mechanic method.
Get yourself a disposable turkey baster and container. Suck out all that bad fluid and replace with fresh.
Be careful of drips as it's caustic to paint.
Drive around a bit. Next week repeat process.
Three cycles and your pretty much equivalent to a pedal/bleed screw flush.
Advantage not messing around with rusty frozen bleed screws and less likely for air contamination.
Works great on master cylinder too.
Enjoy!
2002 Sport Edition (Big Red) 2wd auto, 235k
cahilc is offline   Reply With QuoteReply With Quote
Old 12-13-2021, 01:15 PM #7
Real Name: Patrick
Real Name: Patrick
Enjoy!
That method gets a good amount of the fluid, but never gets all the fluid especially the fluid that is in the calipers or slave cylinder.
Old 12-13-2021, 03:31 PM #8
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Exactly. That first squirt or two out of the caliper or slave cylinder is usually dirty,
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
fluid , fsm , transmission , vague , w59
what fluid do i use for my clutch? L_Carter831 3rd gen T4Rs 1 07-03-2015 03:14 PM
Trans Fluid change and 4wd fluid?? PaulZ 4th Gen T4Rs 9 01-09-2013 02:39 PM
Front/rear differential fluid, trans fluid and transfer case fluid change 88 Kel Varnsen Classic T4Rs 1 05-20-2012 03:26 AM
clutch fluid change jaypapa 3rd gen T4Rs 5 09-25-2011 10:40 PM
Tranny fluid change...which fluid? wm69 3rd gen T4Rs 3 02-12-2008 01:11 AM
