Old 12-10-2021, 02:50 PM #16
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Here is a crappy photo of the top view: (this is old now)
Old 12-10-2021, 11:08 PM #17
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Building my own Roof Rack
I wished the arb base rack was available for the 3rd gen runners. I want something very suttle and low profile. Lowest clearance possible. Footprint of the OE rack roughly. Just something nice low and flat. I could handle it going over the sun roof if it didn’t have some huge valance hanging way out.
I don’t want it to go almost all the way to the glass like most of the full ones do. I know most that buy these things want a fashion statement, but I don’t. I want to be able to tie gear down when needed, and have it out of the way and not a noisy mpg killing impediment.
Neighbor has an AEV JKUR hemi with a really slick flat roof rack. Sits really low on the hardtop.
Flat, low and suttle. That’s it. I’m not saying the other ones out there aren’t cool, but they’re just not for me.
Maybe I’ll just end up rolling my own.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 12-10-2021, 11:49 PM #18
jross20's Avatar
jross20's Avatar
Hey man I totally feel you for the most part. Just about all of the racks that I've seen are way too bulky... But at the same time I don't like the ones that are just flat, I do like that bit of a basket.
I think mine will be pretty sleek if I can manage to complete it, it should be pretty low and compact
Old 12-11-2021, 12:51 PM #19
jross20's Avatar
jross20's Avatar
Um... Just found this while taking measurements... Do I need to tighten it down? As far as I can tell it doesn't leak so I'm afraid to touch it if it's in equilibrium
Old 12-11-2021, 02:15 PM #20
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
I would personally take it out, clean it up, add some silicone, and screw it down, all the way but not too tight. YMMV
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 12-11-2021, 07:58 PM #21
Oregon Runner Oregon Runner is offline
Real Name: Dylan
Oregon Runner is on a distinguished road
Real Name: Dylan
Went down this same road awhile ago but never pulled the trigger. Yes, 80/20 is your best bet in the 40 series. I've installed literally miles of that stuff for machine guarding and it's way better than the Bosch-Rexroth extrusion. Yes, the connectors will be a major cost, esp for the hidden ones. To answer a few of your questions, the rails sit at slight angles down to the side, and are bowed front to back. You will need to make some spacers to get a level base off the rails. I forgot the angle down but the spacers came out to be approx a .300” difference middle to end in height. So if you had a .500 spacer in the middle you'd want .800 at the ends for flat across front to back. A 4 foot level can also verify this. If you have a 3d printer I can drop those spacer files in my link if you want to experiment with them. They are basically blocks that lock into the rail profile and the extrusion profile using the factory T-nuts...hell, you can have any files you want (Inventor format). I didn't detail any rails in cause I felt it would look too square in regards to the lines of our rigs. The nice thing about T-profiles is there are anchor points everywhere. I have some bent metal T-slot anchors I was going to use for tie-down points that would kinda work as well as rails I thought. If you don't have Fusion 360 you'll probably want to get that and become familiar with it. I figured for about 300-350 shipped and a little time you can have a DIY kit that will be way stronger than anything you could ever buy, and heavily modular/customizable. That's with the hidden fasteners, end caps, linear motion for adjustability, locking handles, etc. Again, I'm just sitting on this stuff, so if you want any of it lmk...
Building my own Roof Rack-rr-jpg
Some of my 3Rd Gen 3D printing projects here...hit me up for custom designs
https://www.thingiverse.com/groups/3...4runner/things
Photo Dump of my 4Runner / Toyota projects, TONS of fab and CAD pics...
https://photos.app.goo.gl/hCSpkZ6nLwMPCCXH6
Oregon Runner is offline   Reply With QuoteReply With Quote
Old 12-12-2021, 12:14 AM #22
jross20's Avatar
jross20's Avatar
Oh wow.
So see I was thinking about using external connectors... But seeing as how their are crazy expensive I've been looking for cheaper alternatives.
I think I counted 24 25x25mm (1") L brackets and 16 25x50mm (1"X2") L brackets.
Going to post some more pictures tomorrow. About to pass out... Haha
Old 12-13-2021, 01:13 PM #23
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I would be interested in your spacer files if you don't mind sharing them please.
angled , case , flat , rail , roof
Building a Hang Glider Rack vachss 4th Gen T4Rs 0 05-14-2016 08:08 PM
building a custom roof basket morbidsanity 3rd gen T4Rs 7 10-14-2013 11:34 AM
Thinking of building a 3/4 rack for 3rd gen's Whitson Metalworks 3rd gen T4Rs 14 09-16-2012 07:58 PM
Anyone building custom roof racks for their 3rd gen? airbag 3rd gen T4Rs 6 08-24-2010 10:00 AM
TRADE: Silver roof rack for Black roof rack. trijicon Classifieds - buy & sell (no commercial ads please) 0 04-19-2006 02:38 AM
