Old 12-09-2021, 05:39 PM #1
BryanD BryanD is offline
BryanD is on a distinguished road
Identify this bolt
Found on my driveway just outside the driver's door of my 2000 Limited. Any guesses where this goes?
Identify this bolt-img_2314-jpg  Identify this bolt-img_2313-jpg
BryanD is offline   Reply With QuoteReply With Quote
Old 12-09-2021, 06:18 PM #2
jlaho jlaho is offline
jlaho is on a distinguished road
Not sure if I'm adding much value here, but that doesn't look like a factory Toyota fastener to me. My first guess is it came from somewhere else, or something aftermarket on/in the vehicle.
If it did come from the vehicle, it would guess it came from the inside. Hopefully others can post to help verify this.
jlaho is offline   Reply With QuoteReply With Quote
Old 12-09-2021, 06:35 PM #3
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Identify this bolt
EDIT: @jlaho is right, if it's Toyota, it looks like is from the inside.
Maybe check near the end of your roof rails that run fore and aft?
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 12-09-2021, 09:10 PM #4
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
The door lock actuator uses torx but that bolt looks way too new to be an original bolt for the door jamb area. Most have faded in color considerably.
Any other cars park in your driveway? It may be off another vehicle.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 12-10-2021, 04:47 PM #5
Looks like modern GM to me... Or mid-grade furniture.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-11-2021, 12:41 AM #6
nissanh nissanh is offline
Not a Toy bolt.
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 12-11-2021, 10:53 AM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I basically took a 3rd gen 4 runner down to nothing.. I don't think that's out of a 4 runner . I don't recognize that at all.
Old 12-11-2021, 02:03 PM #8
Awesome, thanks for the responses! I'll check the areas suggested but will keep my search to a minimum since it seems like its not from this rig.
door , drivers , guesses , identify , limited
Can you identify this bolt? meltdowner 4th Gen T4Rs 7 10-30-2018 09:42 AM
Steelcraft Bull Bars - 2 Bolt vs 4 Bolt Versions 4runnator 4th Gen T4Rs 4 07-04-2017 11:07 AM
Body Lift Block ID/Bolt length- Steering Shaft bolt length 02_SE_Runner 3rd gen T4Rs 6 03-15-2013 09:57 AM
Help me identify a bolt, and possibly a solution pbcolt 3rd gen T4Rs 3 07-17-2011 11:46 AM
