12-13-2021, 10:41 PM
BES LIFE 3gen 4runner Modualr panel
(DD)-97 4runner limited Green. Camburg uca, Icon w/700 Rear 210v w/ Foxs, Arb locker, Gear- 4.88 F&R. Tundra Trans cooler. All armor BFF
(Crawler) 95 Toyota pickup 22re, dualcases 4.7, Longfields, 37s, Dual Arbs.
IG: Jaysen4runner
Reason: updated
12-14-2021, 10:00 AM
Interesting I've often thought about trying to mount gauges in part of the din slot once I switch to a single din
What are you thinking about mounting?
12-14-2021, 03:01 PM
Real Name: Evan
Real Name: Evan
Originally Posted by Jaysen4runner
Playing with a modular dash panel mount
I’ve seen these for newer Tacomas and FJ’s and wondered how we could integrate something similar into a 3rd gen without it bolting to the flimsy bezel plastic or drilling into the dash somewhere. What are your thoughts on mounting? I’ll be following the progress on this one closely.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
12-14-2021, 07:20 PM
I've got a small bracket that mounts there on one side to the radio bolts and it vibrates to the point of being basically unusable especially with a tablet. Attaching on both side is probably much better. I can't remember who made the bracket and I've tried shims and things but it still vibrates. It acts like a tuning fork tine on dirt roads. I have another ram mount base bolted to underside of the dash where it starts swooping up over the gauges and it's actually much more solid, I can have a tablet on 4" arm no prob. I spent ages trying to figure out where to mount stuff I'm not sure there is a correct answer. Curious to see how your setup works for you.
99 SR5 v6 4WD
11 SR5 v6 4WD
12-14-2021, 09:19 PM
The modular panel is for phone, mics and ect. I haven't tested yet for a iPad, but it will use a ram ball mount for attachment. It will be screw in thru to the bezel, behind all the prehole there are room for the screws without interference to anything behind the center bezel. Cupholder 96-98 will be unless with this modular panel.
IG: Jaysen4runner
12-14-2021, 09:22 PM
Here is a modular panel from Ohana Rig Supply, it will be a very similar setup as this. This setup use screws to bolt in or adhesive and it hold just fine. I use this setup in my wife Gx470. This setup for the 3gen 4runner should be just as rigid as anything out there.
IG: Jaysen4runner
12-18-2021, 07:21 PM
I'm certainly interested if you offer this for sale! Designing something like this has been on my list for some time.
2000 Limited: Toytec Superflex, 255/85-16, Lil Skips gas tank skid, SaVage rear bumper and skids, BAMF Sliders
2006 SR5: FJC Coilovers +2", Toytec Superflex, 255/85-16
Sold: 2017 TRD OffRoad Prem (this rig was too nice for me!)
12-19-2021, 12:45 AM
Yes, it will certainly be up for a group buy. It's in the process of being water jet and form. Working out the price at the moment. I'll keep you inform
IG: Jaysen4runner
01-08-2022, 02:06 AM
Finally got it, cut and form..preorder will be on FB 3gen 4runner sell and trade group and IG
IG: Jaysen4runner
01-08-2022, 02:43 AM
Real Name: Devan
Real Name: Devan
Super slick!!
01-08-2022, 11:52 AM
How’s the hand access?
With the On X announcement of apple car play support, I’m kinda torn…. The placement is lower is the only thing. It’s nice to have the NAV in my field of view with the windshield.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
01-08-2022, 12:06 PM
You know though, the Placement looks solid on this piece.
With a longer ram mount arm, and say a newer iPhone or iPad mini, will the bezel hold up to solid off-road bump abuse? I probably drive faster than I should sometimes
My ideal scene would be getting the nav up as high as possible without obstruction of view. Currently I use a window ram mount to the right of rear view mirror. Placement works very well, the issues are I have a cord hanging down by my wife since OnX does pull the battery down hard, it messes with my sunshade, and it’s one more step for me to detach to take the phone with me for family photos and all the cool stuff I find off the beaten path.
01-08-2022, 12:34 PM
Real Name: Evan
Real Name: Evan
I really want to move on from my Ram mounts in the Paranoid Fab bracket. Too much wobbling and extensions to get the phone where I want it.
Is your mount too wide for the dash bezel trim if it was moved down a few inches? I know it narrows as it goes towards the bottom of the bezel. If your mount was in between the HVAC and radio you’d have an unobstructed windshield and keep the vents and clock unblocked also when there’s a device mounted. Or maybe it would have to go further down than that to make that possible, IDK. I guess no matter where it’s mounted, something’s getting blocked a little. I’d be interested in an alternate version, or perhaps there’s room to move it down and shape the mount down a little where needed…
02-06-2022, 01:55 PM
Real Name: Matt
Real Name: Matt
No love for us weirdos who don’t facepage?
'98 4WD Limited, Warm Grey, 172k, Factory E-Locker, Ride-Rites, 265/75-16 Wildpeak AT3s
02-06-2022, 09:26 PM
I built this a few years ago and has worked wonderfully for me. The iPad Mini and the iPhone I use to mount here do wobble a bit when on rough roads, but I am good.
I would love to have one of these, but don’t have a need at the moment. Too bad too because I bought the molle panels that sit on either side of the shifter console that would almost tie in with this.
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
