Old 12-22-2021, 01:47 PM #1
repo repo is offline
repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light repo is a glorious beacon of light
Loose crankcase ventilator
The metal right angle hose attachment vent at the back of the driver side valve cover can turn back and forth and is blowing out some oil residue around that hose connection. It's the same kind of vent as the one on the throttle body that the PCV connects to and looks like a permanent part of the valve cover. Is it possible to tighten it back up (preferably without removing the valve cover)? Or should I keep ignoring it?
Side question: what exactly is the foam protector for that goes over the PCV hose vent that I just mentioned on the TB?
99 SR5 v6 4WD
11 SR5 v6 4WD
repo is offline   Reply With QuoteReply With Quote
Old 12-22-2021, 03:12 PM #2
spartacus's Avatar
spartacus's Avatar
The metal pipe is weld on part of the valve cover. Replace the cover or try and jb weld it. The foam peach helps secure and protect the pcv hose going into the upper plenum.
back , cover , hose , valve , vent
painting louver cowl top ventilator PP plastic? sleepydad 3rd gen T4Rs 22 08-25-2018 07:44 PM
Seafoam in Crankcase...Bad? Good? Foghorn 4th Gen T4Rs 19 09-16-2016 01:03 AM
Crankcase moisture videopuppy 4th Gen T4Rs 4 04-15-2016 10:34 AM
1998 3RZ: too much crankcase pressure? 98Base4R 3rd gen T4Rs 3 12-16-2013 02:07 PM
What have you put in your gas tank & crankcase? MikesToy General Discussions 18 12-20-2010 06:36 PM
