Old 02-08-2017, 05:57 PM #1
baja1 baja1 is offline
baja1 is on a distinguished road
coolant lines thru throttle body and....
whats the purpose of coolant thru the TB and is the hose into the idle valve vacuum or just air?
thank you! trying to track down the ol' high idle thing!
baja1 is offline   Reply With QuoteReply With Quote
Old 02-08-2017, 07:02 PM #2
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Coolant lines through the TB is usually for helping to warm up the TB in cold climates. It's often useless and many people bypass it on some motors. I had a leak on my grand prix from the coolant line to the TB and I just bypassed it.
It's also counter productive when it's warm out and unnecessarily heats up the air through the TB, again, why many people bypass it.
Sent from my SM-N910V using Tapatalk
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 02-08-2017, 07:17 PM #3
etc.'s Avatar
etc. etc. is offline
etc. is on a distinguished road
etc.'s Avatar
Helps the TB from icing up.
1996 T4R Limited - stock
1997 T4R Limited - stock
2015 TEP w/KDSS - stock
etc. is offline   Reply With QuoteReply With Quote
Old 02-08-2017, 09:52 PM #4
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
I think it's more for preventing the throttle plate from icing up which can even occur at temperatures above freezing.
I don't think it heats the air up significantly.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 02-09-2017, 12:59 AM #5
who knew? thanks gentleman! I'm a less is more kind of guy, the more I can delete the less there will be to troubleshoot, I understand all these systems are in place for a reason though! thanks!
Old 02-09-2017, 02:39 AM #6
rallypoint_1's Avatar
rallypoint_1 rallypoint_1 is offline
Real Name: Bill
rallypoint_1 is on a distinguished road
Real Name: Bill
I have them bypassed on my Civic and Accord. I also read that the warm/hot TB helps atomize fuel.
1998 T4R SR5 V6 2wd Evergreen Pearl OME 880 Toytec 1/4" spacer OME 906w/OME20mm(10mmx2)spacers Bilstein 5100 BFG KO2 31's Satoshi mod 1.5" BL(Fat Pats)
My 4Runner build:
http://www.toyota-4runner.org/3rd-ge...8-sr5-2wd.html
rallypoint_1 is offline   Reply With QuoteReply With Quote
Old 02-09-2017, 04:43 PM #7
Keep in mind the TB can freeze up at temps above freezing. The air passing through the throttle body in a near-closed position goes to very low pressure, thus lowering temps. Lower temps + possible moisture in the air can freeze up the throttle body.
I've never had a problem with it (bypassed on multiple cars that I have driven in temps below freezing) but it is technically possible. I left it in place on my 4Runner though... not really looking for 'more power' from little things like that on the 5vz.
The other line off the throttle body goes to the 'air assist' for the fuel injectors. See this thread for diagrams: How to Disable Injector Air Assist
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 04-19-2022, 08:40 PM #8
Sparky115 Sparky115 is offline
Sparky115 is on a distinguished road
A PAIN to get to
I have 2000 4runner, 350k miles. What a pain to get to these things. Spring loaded clamps is the only way to go. If you have to replace the hose do not cheap out, get new clamps. You don't want to have to go back in later.
Sparky115 is offline   Reply With QuoteReply With Quote
throttle body coolant bypass pic dunebashing toyota 3rd gen T4Rs 25 05-14-2018 03:57 PM
3rd gen: I ran coolant up my throttle body into my intake. yota-runner Maintenance/Detailing 0 08-02-2015 11:55 AM
Electric throttle body to cable throttle body conversion Dirtyfingers 3rd gen T4Rs 8 12-29-2014 10:05 AM
Anyone know the size of our coolant lines? MeBe4running 5th gen T4Rs 0 07-12-2012 05:47 PM
Throttle body troubles...WOT=half throttle Idahosr5 3rd gen T4Rs 0 10-31-2010 04:09 PM
