Old 12-27-2021, 08:10 PM #1
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Water pump leaking at a bad time
I was turning the crankshaft pully I noticed a red fluid coming from the base of the fan pully (or the water pump pully). I don't remember seeing this leak but my engine is covered in grime from multiple oil leaks, so maybe its not new.
I checked the radiator and the fluid level and I don't see significantly lower levels. This is happening at a really bad time, in less than a week I have to drive my 4runner 1k miles back to college. Once there I wont have time or the resources to do this myself.
I can live with topping off the oil, but a leaking water pump seems more critical. I am also aware that the fan has a fluid coupling component that can potentially leak as well.
How long can I drive with a leaking water pump?
And how long does it take to replace the water pump on a 3rz?
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 12-27-2021, 10:10 PM #2
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I have the 3.4l but if its a small leak you will probably be fine for a while until you replace the pump but you do have to keep an eye on the reservoir tank and top up every once in a while. Severe case, you shouldn't be driving it until the water pump is replaced.
My OG water pump made it 220k until it got replaced and that thing was a hidden MESS - I don't know how long it has been leaking for but it still ran at operating temp.
2000 4Runner Limited 4x4 V6
Old 12-27-2021, 10:40 PM #3
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
The water pump on the 3RZ is easy. If memory serves you take off the accessory belts and fan clutch and then it’s right there on the front of the motor. You might want to pull the radiator for more room but that’s easy. Get an Aisin unit and you’ll be good to go!
JZiggy is offline   Reply With QuoteReply With Quote
Old 12-27-2021, 11:18 PM #4
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
Does the fluid coupled fan clutch often leak on these?
Old 12-27-2021, 11:29 PM #5
JZiggy's Avatar
JZiggy's Avatar
Probably less likely, but it can also be easily replaced with an Aisin part. You’re taking it off to do the water pump anyway.
Old 12-28-2021, 12:16 AM #6
Pyral's Avatar
Real Name: N/A
Pyral's Avatar
Real Name: N/A
I'll add some dye to the coolant. The fan clutch cost about $180, so I want to be sure it is leaking. The water pump definitely is.
That water pump gasket sure has an interesting shape to it.
Old 12-28-2021, 07:20 AM #7
JZiggy's Avatar
JZiggy's Avatar
Water pump = Aisin WPT-044, $47
Fan clutch = Aisin FCT-002, $102
Rockauto prices. Those are OEM equivalent parts.
Old 12-28-2021, 12:24 PM #8
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
As far as I know the fan clutch fluid is clear. Not red.
If your fan clutch is working properly it's probably not leaking.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 12-28-2021, 12:34 PM #9
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
This right here. You would know if the fan clutch was not working.
You can do the Water Pump in 2 or 3 hours with basic tools. Don't put this off an risk a catastrophic failure on the road home and risk blowing your engine! I almost blew my 3.4 because I was putting off the timing belt, knowing I had a small leak. Ended up losing way more coolant than I thought and redlining as I was hooking up a Uhaul trailer!
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 12-28-2021, 01:49 PM #10
BlackCloud's Avatar
BlackCloud BlackCloud is offline
BlackCloud has a spectacular aura about BlackCloud has a spectacular aura about
BlackCloud's Avatar
I once suffered a leaking water pump in Nebraska while driving x country. Now THAT's a bad time to suffer a breakdown. Anyway, I was able to literally limp 100+ miles into Cheyenne, WY and get it swapped out the next day.
BlackCloud is offline   Reply With QuoteReply With Quote
fluid , pully , pump , time , water
Water pump leaking? EddieV4runnin 5th gen T4Rs 5 08-15-2020 03:00 AM
Leaking water pump?? SeanWN86 4th Gen T4Rs 3 04-01-2018 04:28 PM
V8 water pump leaking (again) vanion2 4th Gen T4Rs 30 04-16-2017 03:53 PM
Leaking water pump @ 63K 04 sc V8 Problems & Warranty Issues 6 05-04-2009 12:37 PM
water pump leaking dredhaus 3rd gen T4Rs 5 01-14-2006 01:50 PM
