Old 01-13-2022, 01:27 PM #16
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Originally Posted by Jason_nakal View Post
Yes, it sounds like you might have the same thing. It’s not a difficult part to change, you can do it in less than an hour. That said, it’s also not expensive to get an OEM one, they’re around $55 plus shipping (you’ll also need 5 crush washers). I just went with the OEM. Less than $100 to fix something two mechanics couldn’t (wouldn’t bother, really) figure out.
Thanks - does the pic I added in my previous post show the correct location? I found it on an older thread here...
5 crush washers??
Old 01-13-2022, 02:45 PM #17
19963.4lsr5 19963.4lsr5 is online now
Have you looked at the ECT sensors temp in live data? It is easy to tell if it’s bad or not.
Let it sit overnight and compare the IAT and ECT sensors to your ambient temp. When it’s warmed up use a temp gun.
19963.4lsr5 is online now   Reply With QuoteReply With Quote
Old 01-17-2022, 10:41 AM #18
Jason_nakal Jason_nakal is offline
Jason_nakal is on a distinguished road
So this did NOT actually fix it. Unclear why I got a couple of warms starts out of it initially, but it is as before now.
Back to the drawing board.
Of you do change the coolant temp sensor - I can’t see the pic me mentioned - but it’s between the banks in the front behind the timing below cover. Yes, five crush washers, once for the sensor and four for the fuel rail banjo bolt you’ll need to remove for access.
Jason_nakal is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 10:58 AM #19
How do I view live data? I have a basic code reader only. Specialized tools, presumably.
My latest thoughts are the throttle body (control…? It’s been cleaned 2x now) and the upstream air/fuel/O2 sensor. It has thrown a p0171 code once or twice.
Old 02-05-2022, 07:17 PM #20
Post script for anyone who runs into a similar problem—it was the fuel pump.
Old 02-20-2024, 12:18 AM #21
Jodaddy.1 Jodaddy.1 is offline
Jodaddy.1 is on a distinguished road
Jason, did you have anymore idle issues after the fuel pump was replaced?
Jodaddy.1 is offline   Reply With QuoteReply With Quote
Old 02-23-2024, 05:30 PM #22
prybar's Avatar
prybar prybar is offline
prybar is on a distinguished road
prybar's Avatar
It's pretty easy actually. Just order a Bluetooth OBD dongle online, and you can hook your phone up to it and view all sorts of data that you can't see on your average OBD scanner. Dongles are about $10-15 and it's pretty cool to be able to see all your vehicle data. Some people also recommend getting an on/off switch for the dongle since they typically have LEDs on them and can drain your battery if you don't drive it for a week, but that's more a preference thing (I do have the on/off switch for peace of mind). Switch should be around $5.
'99 Limited, 260k
prybar is offline   Reply With QuoteReply With Quote
Old 02-25-2024, 09:55 AM #23
arrrdubb's Avatar
arrrdubb arrrdubb is offline
arrrdubb is on a distinguished road
arrrdubb's Avatar
I'm having this exact same issue. Any issues after replacing the fuel pump?
arrrdubb is offline   Reply With QuoteReply With Quote
back , it’s , kind , start , starts
Warm start problem tomzapf Maintenance/Detailing 16 01-10-2022 01:23 PM
Warm Start Issue(5-20 min after stopping) 1997 3.4L V6 rorikk 3rd gen T4Rs 21 01-06-2021 06:30 PM
Hard start warm sawguy 3rd gen T4Rs 4 09-29-2018 11:17 AM
98 T4R won't start after engine is warm protheroe1 3rd gen T4Rs 30 03-07-2017 03:52 PM
Dies after start/low idle on warm start Hogmoss 3rd gen T4Rs 3 10-19-2009 11:36 AM
