Old 12-30-2021, 09:55 AM #1
FLYNAVY53 FLYNAVY53 is offline
FLYNAVY53 is on a distinguished road
New to the 3rd Gen....any way to remove/disable factory alarm?
I just inherited my family's old 2002 4Runner. My first order of business, how do I remove or disable the terrible factory alarm/keyless entry??
The key fob only works half the time, and while the key will unlock any door, it only disarms the alarm if used in the driver door which is extremely annoying. That combined with the fact that the alarm arms itself within 60 seconds of the door being closed, I find myself setting off the alarm multiple times a day.
I'd prefer to remove the system entirely and simply use the key to lock/unlock all of the doors.
Thanks for the help!!
FLYNAVY53 is offline   Reply With QuoteReply With Quote
Old 12-30-2021, 10:20 AM #2
eimkeith's Avatar
eimkeith eimkeith is offline
Official Vendor
eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light eimkeith is a glorious beacon of light
Official Vendor
eimkeith's Avatar
on our '96, I just unplugged and removed the brain under the driver's seat.
keith
eimkeith.com
all product descriptions © eimkeith LLC 2016-2024
eimkeith is offline   Reply With QuoteReply With Quote
Old 12-30-2021, 10:21 AM #3
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
These 4runners have an Alarm? You sure it's OEM? Mine is 100% OEM and is only keyless entry (lock, unlock doors and roll down rear window). The key is chipped for an immobilizer system, but that's just a start/no-start system. There's no siren, which is what I associate with an alarm.
Try checking the wiring loom that runs to the back hatch (next to the drivers side hinge of the hatch) for breaks/burns/damage as that's a known problem area and would impact the function of the keyless system (brains are in the hatch).
Maybe there's a difference between the '99 I have and your '02?
Brian. is offline   Reply With QuoteReply With Quote
Old 12-30-2021, 12:24 PM #4
ZSW99 ZSW99 is offline
ZSW99 is on a distinguished road
My 99 definitely has an alarm. I routinely set it off accidentally also. I did some research on how to disable the alarms and auto lock features but retain keyless entry a while ago but couldn’t find much information. My understanding is that there might be a few different versions of the system based on trim level and year. Hopefully someone will shed some light on it
98 Base 4x4 3rz 380k
96 Taco rcsb 4x4 3rz 320k
ZSW99 is offline   Reply With QuoteReply With Quote
Old 12-30-2021, 02:05 PM #5
The '99+ will all have OEM keyless entry, but the alarm system is optional.
Based on the features, it sounds like it might be aftermarket. Either way though, it can be removed.
Post a picture of the fob so we can verify if it is OEM first, then we can go from there.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-30-2021, 03:09 PM #6
Thanks guys....definitely factory. Here are the pics of the key fob front and back, as well as the original window sticker. Its funny that it lists the keyless entry with remote, but does not say anything about the alarm...
Old 12-30-2021, 06:46 PM #7
The google links generally don't work for linked images. Try imgur or any number of other image hosts.
Old 12-30-2021, 07:12 PM #8
Ghostrider Ghostrider is offline
Ghostrider will become famous soon enough
I would be shocked if the sticker said alarm. I have had my 01 since new and it definitely did not come with an alarm. I believe any alarm is installed as a dealer option or third party
Ghostrider is offline   Reply With QuoteReply With Quote
Old 12-30-2021, 07:20 PM #9
Charlie, are the photos not visible? I can see them with no issue, but perhaps that's because I posted them?
Old 12-30-2021, 07:22 PM #10
That would make sense. I may need to just start tracing wires backwards from the speaker to sort out where they go. It definitely has that terrible, '90s Lo-Jack alarm sound to it.
Old 12-30-2021, 07:40 PM #11
Shadco Shadco is offline
Shadco is on a distinguished road
My 2000 limited has factory alarm and it is malfunctioning.
Shadco is offline   Reply With QuoteReply With Quote
Old 12-30-2021, 10:00 PM #12
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades has much to be proud of Endlessblockades has much to be proud of Endlessblockades has much to be proud of Endlessblockades has much to be proud of Endlessblockades has much to be proud of Endlessblockades has much to be proud of Endlessblockades has much to be proud of Endlessblockades has much to be proud of
Real Name: Blair
My 2000 LTD has some kind of fancy factory immobilizer and horn alarm that works fine so far.
Y2K LTD/E 265K
Old 12-31-2021, 07:41 AM #13
I might need to correct this. Mine is SR5 not a Limited. I still have the sticker and know for a fact that there is no alarm from Toyota. The Limited might be different.
Old 12-31-2021, 07:56 AM #14
Brian.'s Avatar
Brian.'s Avatar
Trust me, the immobilizer system is only a start/no-start thing. I've been completely through it to code new keys instead of paying Toyota ~$1200 to get keys. There's no alarm on that part of the system.
Maybe I'm doing it wrong (with regards to the alarm), what EXACTLY are you people doing to set it off?
Old 12-31-2021, 12:20 PM #15
Most common scenario is you open the door with the key but didn’t click unlock on the fob. This will always set the alarm off on mine. It happens every time my girlfriend drives my 4Runner because her 3rd gen doesn’t have keyless entry and she just habitually puts the key in the door first
alarm , door , factory , key , remove
Disable factory alarm? Cow_doc.308 3rd gen T4Rs 4 03-24-2019 09:28 PM
Disable Factory Alarm 2011 TE maulihiwa 5th gen T4Rs 4 05-09-2016 01:35 PM
How To: remove the factory alarm 2nd gen TX_QtPi Classic T4Rs 7 10-04-2015 07:23 PM
How can I disable the factory security/starter disable? jmyer72 3rd gen T4Rs 6 08-16-2015 08:32 AM
Disable the Alarm drukjojo 3rd gen T4Rs 0 05-30-2015 12:49 PM
