Old 01-06-2022, 08:46 PM #16
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
Originally Posted by Bad Luck View Post
OTC makes Snap On and Matco's compression testers and leak down testers. I'd recommend OTC over anything else out there.
thanks. I will look into getting an OTC compression tester. this summer I want to retest mine and one of my grandsons wants to get a older taco. of course my 4runner at 245k is using no oil, no antifreeze....great engines.
Old 01-06-2022, 10:33 PM #17
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Originally Posted by Pyral View Post
To remove the spark plug tube you have to remove the head. Its not easy.
I lucked out and found a pipe that fit around the edge of the adapter and spun it out. So I don't have to worry about taking it to a mechanic on 3 cylinders.
My gf lost/hid her lug lock key a couple times. We still get tires done at a local shop which is where I learned about these extractors - Amazon.com: Eapele Impact Bolt Nut Removal Extractor Socket Tool Set with Center Punch Bar (6pcs) : Tools & Home Improvement
She declined his offer that day but I still bought a set. If it happens again... Anyway, that set is too big given what you described but they probably make smaller versions, might work if anyone else finds themself in the same boat someday.
OTC makes quality tools, just sucks they're mostly made in China for the price they charge when in many cases you can get USA made for less - Amazon.com: Lang Tools CLT-2 100 PSI Cylinder Leakage Tester with 2 Gauges : Automotive Even the $500 hub grappler kit I think only the puller itself is still made here.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
adapter , engine , hose , metal , tester
compression test and a leak down test cost? judoant 3rd gen T4Rs 23 05-24-2018 04:34 PM
5VZ-FE 3.4L V6 Compression Test mtbtim 3rd gen T4Rs 3 01-02-2018 04:29 PM
How to run a compression test? a216vcti 3rd gen T4Rs 8 02-07-2014 07:14 AM
Compression test... LittleCaesar 3rd gen T4Rs 9 06-11-2011 02:05 AM
