Old 01-02-2022, 03:01 PM #16
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
folowing as I need to do my bushings this summer. prob 50 50 pavement and gravel roads so harshness would be no fun. I also have to replace one lower control arm as it is bent, from previous owner
Old 01-02-2022, 06:47 PM #17
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Pulled the trigger on Whiteline bushings. They offer all bushings for the rear suspension, total came to $175 or so.
Figured it would be a good winter project as I have 06 Saab SportCombi 2.8 w/6 speed manual for winter use.
Will update thread once I find the time to complete the install.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 01-03-2022, 02:57 PM #18
alia176 alia176 is offline
alia176 will become famous soon enough alia176 will become famous soon enough
Originally Posted by Sarki View Post
Again, this is my daily driver so looking for comfort and durability more than anything else.
Thanks!
I'm late to the party so I didn't read the entire thread but this statement points to OEM bushings. They last a long time, as you found out! Nothing else will be as long lasting, period.
Whitline bushings have a good rep and the cost is prolly better than OEM.
2003 Sport V8 Icon 2" rear, Bilstein 6112 front with 700# king springs, Gibson cat back, Magnaflow cross pipe. OBA, DIY sliders, etc
1996 FZJ80 landcruiser with whole bunch of stuff, including a Turbo.
1997 4Runner SR5 - daughter's ride, slowly getting built up
alia176 is offline   Reply With QuoteReply With Quote
Old 01-11-2022, 07:36 PM #19
Finished replacing the rear lower control arm bushings.
What an improvement as the originals were toast.
Next up, upper arms and panhard.
Any install tips?
Rear suspension bushings-Daily Driver-251c2e51-8d92-424e-a918-0b62a9acb574-jpg
2002 SR5 Sport 4WD
Old 01-11-2022, 08:03 PM #20
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Any install tips?
2nd verse, same as the first....
Panhard was the easiest of them all. I had issues with the rear control arms and getting the axle to line up nicely, so plan on using a comealong or heavy duty ratchet strap, probably a jack or two and maybe a prybar to help get everything lined back up again.
And wow, that's crusty... glad I bought a TN truck and live in GA
Brian. is offline   Reply With QuoteReply With Quote
Old 01-11-2022, 08:07 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
My originals on my 98 looked alot worse thrn those. Good call though as those bushings are gone.
Old 01-11-2022, 08:21 PM #22
Holy cow, can’t imagine worse than what I took out but given the crap they throw on our roads in the winter I can only imagine what your looked like.
Can’t wait to do the upper arms and panhard.
2002 SR5 Sport 4WD
Old 01-11-2022, 08:25 PM #23
I used a ratchet strap as the rear axle definitely shifted on me as well once I removed the lower arm.
Removing the old crusty bushing was a bit of a battle that took most of the time.
Once I finish up the rear I’ll probably move onto the front upper & lower control arm bushings which I know isn’t a fun job.
2002 SR5 Sport 4WD
Old 01-12-2022, 09:42 AM #24
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Any install tips?
Do the upper control arms one side at a time to minimize axle shift. If it does shift some ratchet straps are very helpful to get it to line back up. Do the panhard bar with the tires on the ground.
Old 01-12-2022, 10:49 AM #25
Ahhh, exactly what I was looking for regarding the panhard bushing replacement.
I figured best to do the upper arm bushings same way as the lowers, up in the air with no load on rear suspension but wasn’t sure if that applied to the panhard.
Thanks for the heads up on that, very helpful.
2002 SR5 Sport 4WD
Old 01-12-2022, 10:55 AM #26
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
2nd on do the control arms one at at time. That's how I do them abd making the job alot easier.
Old 01-12-2022, 11:03 AM #27
Real Name: Patrick
Real Name: Patrick
You're welcome. I forgot to add that if the panhard doesn't line back up for reinstall if you jack up on the frame on the passenger side (or preferably a tow hitch if equipped) it will move the two mounting points further away. If you need them closer together you can try adding weight to the cargo area or using a ratchet strap between the passenger side of the axle and the passenger side frame above it (essentially you are trying to compress the right rear suspension).
Old 01-12-2022, 11:49 AM #28
Fortunately I have a 4 post lift and a hoist stand available for this suspension work, makes this type of work much more pleasant.
When I replaced the lower arm bushings I supported 3rd member with the hoist stand.
Once supported I replaced the bushings in each arm one at a time. Still needed the ratchet strap as the rear diff shifted ever so slightly.
Thinking once up in the air I’ll use the hoist stand to stabilize the panhard and try and maintain it’s original position hoping reinstall goes easy and all lines up.
Rear suspension bushings-Daily Driver-a93d6257-2a24-4ee1-82e1-daa4094cff12-jpeg
2002 SR5 Sport 4WD
Old 01-13-2022, 04:29 PM #29
JustTroItIn's Avatar
JustTroItIn JustTroItIn is offline
JustTroItIn is on a distinguished road
Does the Panhard bar bushings have a metal sleeve like the upper control arms or is it just a rubber bushing like the lower?
2000 Limited w/ rear locker
-Dobinsons IMS, JBA UCA, Whiteline Bushings
2000 SR5 4WD Auto w/ J Shift
-Stock Beater
JustTroItIn is offline   Reply With QuoteReply With Quote
Old 01-13-2022, 04:57 PM #30
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
The panhard is like the rear upper control arms where you need to cut around the edge of the bushing to press it out. The rear lowers are different being a press fit metal sleeve.
Skulking is offline   Reply With QuoteReply With Quote
bushings , daily , driver , rear , suspension
Planning on doing all NEW OEM bushings in front and rear suspension. Any suggestions? nissanh 3rd gen T4Rs 15 11-22-2022 03:27 PM
FS: 3rd Gen Energy Suspension Rear Control Arm Bushings - $80.00 - Denver,CO Mzs14 For Sale: Suspension/Wheels/Tires 0 09-09-2018 07:51 PM
Suspension recommendations for a daily driver jerad 5th gen T4Rs 15 11-24-2016 03:55 AM
daily driver goes off road tires/suspension rhymevigilante 3rd gen T4Rs 1 01-22-2007 01:53 AM
