Old 12-31-2021, 01:08 PM #1
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Rear suspension bushings-Daily Driver
After returning home from a 3K mile road trip in my 02 Daily driver w/200K miles on the odometer, thinking it’s time to replace rear suspension bushings.
Felt a bit of side to side movement in the rear at highway speeds, nothing serious but enough to notice.
Will probably do the front upper & lower control arm bushings as well but starting at the back.
Normally stick with OEM but see many have gone Whiteline or Energy Suspension.
Can you guys that have replaced the rear bushings chime in with your thoughts & experience regarding which bushings you went with and if you’re happy about selection.
Again, this is my daily driver so looking for comfort and durability more than anything else.
Thanks!
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 12-31-2021, 01:53 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Daily driver here too (wifes), and I did the Whiteline route where ever possible after watching Timmy and Seans videos. So, SO much better ride than the loose and worn out OEMs, easily the single best thing I've done to improve the ride quality. We have 2 years and ~10k miles without issue or complaint.
If you're a DIYer and cost conscious, then OEM isn't for you. If you're not going to press out and in the bushings yourself, then Maybe going OEM might be a better option from a cost perspective (vs hiring a shop to do the press work).
The link in my sig has all the info on what I did as well as links to the pertinent videos.
Brian. is offline   Reply With QuoteReply With Quote
Old 12-31-2021, 02:01 PM #3
Exactly what I’m looking to hear Brian!
Watched Timmy’s video on this already and do my own stuff so good to go.
Another project for the 20 ton HF press helps recoup the cost after buying it for the rear axle shaft seal replacement��
Looks like Amazon has a complete Whiteline bushing kit for just under $175 so if going with Whiteline I’ll go that route.
Will take a look at the links you have listed as well, the more info the better.
Thanks for the input!
BTW……I’m a T100 guy as well. Started with a 96 SR5 Auto 4x4 and now have a 95 SR5 4x4 5 Speed manual……THE best trucks!
2002 SR5 Sport 4WD
Old 12-31-2021, 02:24 PM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Since you mentioned my videos, I figured I'd post them here.
Old 12-31-2021, 02:52 PM #5
Brian.'s Avatar
Brian.'s Avatar
Don't forget the panhard bar bushings, I still had a slight side to side sway with all the rest of the bushings done (well, not body, those are still OEM) that was resolved when I did those 2.
Old 12-31-2021, 03:26 PM #6
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
White lines and energy suspension are great in the rear and easy to install, no noticeable increase in harshness like people say they get with poly front bushings
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 12-31-2021, 03:41 PM #7
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes I have a few bushings in need of Replacement. Good to have some feedback on the rear axle alternative bushings.
Old 12-31-2021, 06:24 PM #8
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
I'll go against the tide here and say if it's a daily driver, go with rubber for comfort. I had polys in the rear and just swapped over to rubber and the difference in road noise and harshness is very noticeable. I want to swap the front control arms over to rubber (energy suspension now) because I don't want the hard ride in the front
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 12-31-2021, 06:38 PM #9
Thanks for chiming in as any harshness was one of my concerns since this is my DD.
Big thanks!
2002 SR5 Sport 4WD
Old 12-31-2021, 06:45 PM #10
Interesting……yeah ride harshness is the enemy as that gets tired real quick.
Doing my best to find the right path forward as I usually put 15-20k miles per year on 4TR and another 10K on veh #2.
2002 SR5 Sport 4WD
Old 12-31-2021, 06:53 PM #11
Brian.'s Avatar
Brian.'s Avatar
Big thanks!
That's a hard thing to identify. Everyone has different experiences, different levels of tolerance, and different levels of vehicle build. I would Never use the term "harsh" to describe my 4runner with Poly bushings all around, my wife either (and yes, I've brought this up with her while driving specifically because of all the comments I've seen).
But, just because I don't think it's harsh, doesn't mean you will feel the same way. Just because Twisted Sid thinks it is harsh, also doesn't mean you will feel the same way. Only you will b able to decide. For me, it was simply a money thing, I could do every bushing (they all more than needed it at 192k miles) with poly for less than just the front or just the rear in rubber. It's no more harsh than my 2018 Ford Transit van (roughly the same), less so than our now-sold 2018 Mazda3 or the VW Jetta TDI before it. Really hard to compare to my old T100 as the Substantial difference in handling takes most of the attention, but it may be a little firmer (not harsh, just firmer) than that with it's 2 decade old OEM bushings.
Old 12-31-2021, 06:53 PM #12
If you’re really worried about harshness you can do poly in the uppers since the factory bushings aren’t replaceable, and poly in the pan hard with oem rubber in the lowers which will probably contribute the most to harshness. Toyota only sells new upper control arm assemblies and aftermarket rubber is junk so I’d put poly in those.
Harshness is definitely subjective, I have full poly suspension and poly motor and transmission mounts and to me it’s real smooth and I daily drive it, others would say that setup isn’t even street drivable
Old 12-31-2021, 07:11 PM #13
Appreciate all the feedback and thoughts regarding ride quality.
Like most who have offered their feedback, I’m a car guy through and through so feedback from the road is important to me. I’m not looking for a marshmallow type ride.
Totally correct, each person has a different definition of harshness. I lean towards the more feedback the better, just want to avoid anything jarring or excessively harsh as that gets old quick when on a road trip.
2002 SR5 Sport 4WD
Old 12-31-2021, 10:18 PM #14
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Got complete set of SuperPro bushings for the rear of my 4th gen, just finished painting lower arms tonight. I bought new uppers/lowers and removed the bushings, but not OEM. Will install come spring.
Old 01-02-2022, 12:45 PM #15
JustTroItIn's Avatar
JustTroItIn JustTroItIn is offline
JustTroItIn is on a distinguished road
I can't speak for new OEM feel but I replaced the very worn bushings on my limited with Whiteline and have been very happy with the handling results.
2000 Limited w/ rear locker
-Dobinsons IMS, JBA UCA, Whiteline Bushings
2000 SR5 4WD Auto w/ J Shift
-Stock Beater
JustTroItIn is offline   Reply With QuoteReply With Quote
bushings , daily , driver , rear , suspension
Planning on doing all NEW OEM bushings in front and rear suspension. Any suggestions? nissanh 3rd gen T4Rs 15 11-22-2022 03:27 PM
FS: 3rd Gen Energy Suspension Rear Control Arm Bushings - $80.00 - Denver,CO Mzs14 For Sale: Suspension/Wheels/Tires 0 09-09-2018 07:51 PM
Suspension recommendations for a daily driver jerad 5th gen T4Rs 15 11-24-2016 03:55 AM
daily driver goes off road tires/suspension rhymevigilante 3rd gen T4Rs 1 01-22-2007 01:53 AM
