Old 12-31-2021, 10:14 PM #1
TRD 4RNR's Avatar
TRD 4RNR TRD 4RNR is offline
TRD 4RNR will become famous soon enough
TRD 4RNR's Avatar
Question Causes of an intermittent P0171 ?
What else should I be looking at as the potential cause of an intermittent P0171 (the yellow check engine light goes on & off every couple of days)
I have a ScanGauge - anything I can check with it to help get to the bottom of this?
Supercharged
CA emissions (w/dual cats)
- I've cleaned the MAF
- Using a Toyota Paper Air Filter
- Replaced both the AF & O2 sensor (with Denso)
Thank you and Happy New Year
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
TRD 4RNR is offline   Reply With QuoteReply With Quote
Old 12-31-2021, 10:24 PM #2
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
(CA emissions w/ dual cats)
Lean could mean a leak. Inspect your hoses for damage, and if you want, you can spray something flammable like carb cleaner around the various hoses listening for the RPM to change to try and track down the source of the leak.
Skulking is offline   Reply With QuoteReply With Quote
Old 12-31-2021, 11:31 PM #3
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
The big throttle body hoses can/do crack and/or the clamps get loose over time.
If you haven't already, use only Denso sensors. Aftermarket ones often just
don't work. I chased this code, and it took longer because the replacement
non/Denso rear O2 sensor was off. Replaced it with the original eventually. My
problem turned out to be the front A/F sensor.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 12-31-2021, 11:40 PM #4
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
You can use a smoke machine for the hoses to see if one is leaking. Very handy tool to have/use.
2000 4Runner Limited 4x4 V6
Old 01-01-2022, 12:26 AM #5
TRD 4RNR's Avatar
TRD 4RNR's Avatar
I used Denso
I'll check for cracks and/or loose clamps.
Might be time for a smoke machine.
Thank you
Old 01-01-2022, 12:57 PM #6
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Here is the cause of an 0171 on mine, largest air intake 'hose' nearest intake had a crack that could only be seen if pulled apart just a hair yet the leak was there regardless, went OEM and smilin' since!
Causes of an intermittent P0171  ?-new-air-intake-hose-jpg
Old 01-01-2022, 08:28 PM #7
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I just did this over the weekend, along with the A/C idler pulley. What a world of difference it made in the power and sound. I was about to start troubleshooting a phantom miss at idle, but the Boot was the cause of all my issues!
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 01-15-2022, 03:29 PM #8
TRD 4RNR's Avatar
TRD 4RNR's Avatar
@jgue467
I bought the part in your post and went to install it today and found the hole in the side to be much larger in the new one. Should I have ordered something different? Or do I need a different plug?
Thanks
Causes of an intermittent P0171  ?-screenshot_20220115-112658_gallery-jpg
Old 01-15-2022, 04:08 PM #9
spartacus's Avatar
spartacus's Avatar
@jgue467
Thanks
They have different air cleaner hoses for build date.
17882-62010 5VZFE..VZN18* (07/1998 - 07/2000)
17882-62020 5VZFE..VZN18* (08/2000 - )
air , intermittent , p0171 , paper , toyota
P0171 Yisroel K 3rd gen T4Rs 9 06-26-2020 12:36 AM
P0171 TN4Runner07 3rd gen T4Rs 4 02-16-2020 06:18 PM
Dtc p0171! Evo3742 3rd gen T4Rs 9 06-03-2017 09:33 PM
P0171 Ehab 3rd gen T4Rs 6 03-28-2016 11:20 AM
p0171 won't go away ocreptileguy 3rd gen T4Rs 8 03-22-2015 05:31 AM
