Old 01-04-2022, 03:51 PM #16
coues7 coues7 is offline
coues7 is on a distinguished road
Originally Posted by MTRunner00 View Post
I just relocated from Central WA to Billings MT. You don't know how good we had it there with all the parts floating around. Between both junkyards here I've picked apart all 8 4runners I could find. Next nearest yard is in Missoula that has a 3rd gen in it. 4 hr drive. In WA parts are everywhere and not rusted to shit.
I would R/R the entire engine. Faster and then do Head Gaskets on old motor when its summertime and sell it off.
What is R/R?
coues7 is offline   Reply With QuoteReply With Quote
Old 01-04-2022, 03:59 PM #17
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by coues7 View Post
What is R/R?
It's mechanic short speak for "remove and replace". AKA remove your old engine and install a different engine.
Old 01-04-2022, 04:43 PM #18
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
Sadly, I don't know that I'm setup to do any of that. It's the middle of winter here in Wyoming so I can't move my vehicle into the garage for 2 months. It'll have to go to a shop.
Anyone know of any good shops in northern colorado.
With some research, eBay heads, and Ishino gasket set from Yota1 you could have it done in a weekend. I wouldn't touch the bottom end or swap motor personally. Redid the top end on mine at 185k and leakdown test was over 90% on all cyclinders if I recall correctly. Not to say something couldn't break on the bottom end, but bottom end issues are pretty rare on this motor. I reused my heads which was an adventure in itself with some machine shop issues, so that took a while, but if you go with a reputable builder it should go quickly.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 01-04-2022, 10:17 PM #19
JohnMc JohnMc is offline
JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all JohnMc is a name known to all
I wouldn't even really plan on new heads. It probably has one of the earlier HG designs. IIRC they went through 4 iterations before ending up at a pretty bulletproof MLS design. The earlier composite/partial composite styles will eventually fail with enough heat cycles. The aluminum had and iron blocks expand at different rates as they warm up, which gently scrupbs the HG between them. Enough cycles and it will start leaking.
Since you haven't overheated it yet, just faint signs of a leak, I'd bet the heads are still good. Take both heads off (if one went, the other is likely not far behind), eyeball the cylinder bores while it's apart, put it back together with a new TB/WP kit and new belts/hoses. And while they still sell some off the earlier iterations of the headgaskets (I think) go ahead and get the last style, order one for a 2002 4Runner.
JohnMc is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 12:32 AM #20
jbtvt's Avatar
jbtvt's Avatar
Yea I didn't mean they'd be warped but both head gaskets I've done on the 3.0 and 3.4 the heads had noticeable pitting around the water jacket. Guessing from the aluminum oxidizing and getting sucked into suspension in the water running over it before the leak works its way to the outside of the gasket over the years. It's best practice to get heads resurfaced to get a tight seal and extend the lifespan of your work, especially with the MLS gaskets which last longer with a flat surface, but aren't as forgiving. Supposedly it can also be done with a block and sandpaper if you're on a budget, or just skipped if you're less concerned with longevity than the budget. I've always brought mine to a shop but that takes time, and then you have to measure and order shims which takes more time
edit to add you may not need shims either if you don't get the valves done, but well worth doing them also while it's out in my opinion, about the best bang for the buck you can get for a power increase
Old 01-05-2022, 01:52 AM #21
Krispydixie Krispydixie is offline
Real Name: Kris Dixon
Krispydixie is on a distinguished road
I have two broken down 2000 sr5's I want to work on as project cars. Any suggestions on where I should start repairs? one leaks coolant into the passenger floor and one emits white plumes of smoke from the exhaust.
Krispydixie is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 02:00 AM #22
jbtvt's Avatar
jbtvt's Avatar
You'll get better responses starting your own thread, but the passenger leak is probably the heater core which is an easier and much cheaper fix than a head gasket, which is usually the cause of white smoke. But worth confirming with a leakdown test. You might make a build thread and ask questions as you go
Old 01-05-2022, 02:21 AM #23
Theratk1ng Theratk1ng is offline
Theratk1ng is on a distinguished road
[cod[/code]
Theratk1ng is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 05:03 AM #24
The YotaShop head replacement kit has everything required to replace a set of head. From timing belt, to VC seals, to valve stem seals, to new head bolts to exhaust gaskets and donuts. I’ve used them three times now.
3rd , exhaust , gauge , motor , recommendations
Coolant Leak - 1997 4runner, V6, 4WD toytinker 3rd gen T4Rs 12 09-27-2018 09:28 AM
exhaust flange gasket failure, 1997 tobers 3rd gen T4Rs 0 09-20-2018 02:04 PM
Possible residual coolant in exhaust? babowc 3rd gen T4Rs 0 08-06-2014 09:49 PM
Exhaust in my coolant 22RE? ramminyota Classic T4Rs 5 03-12-2010 02:48 PM
1996 -1997 4RUNNER 2-4wd stainless steel exhaust for sale. Gumballf355 Classifieds - buy & sell (no commercial ads please) 0 09-21-2009 10:50 PM
