Old 01-05-2022, 04:14 PM #1
FLYNAVY53 FLYNAVY53 is offline
FLYNAVY53 is on a distinguished road
Roof rack delete strips...where to buy...or trade for OEM roof rack??
I'm pulling the OEM roof rack off my '02 SR5. We have a Gobi rack on my wife's '16 TRD Pro, which we use for camping etc, so I'm going for the clean look on my T4R. Does anyone know where to find the factory roof rack delete panels, or does anyone with a truck that didnt come with a roof rack want to trade their panels for a complete OEM roof rack??
Thanks!!
FLYNAVY53 is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 07:13 PM #2
gtojimbo's Avatar
gtojimbo gtojimbo is offline
Real Name: jim
gtojimbo is on a distinguished road
gtojimbo's Avatar
Real Name: jim
Thanks!!
they're obsolete -- the toyota part # is 0278-35966 cover strip. my runner came with them and i like the clean look but finding a good set is super hard.
99 sr5 manual 4 wheel drive
gtojimbo is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 08:11 PM #3
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I just took off my tall crossbars. I am going to paint the rack silverish to blend in more with the roof. I thought about deleting it, but again, the strips are discontinued. Another idea I had was some Flat Aluminum Strips painted silver gray or black, drilled to bolt in the OEM spots.
Roof rack delete strips...where to buy...or trade for OEM roof rack??-capture-jpg
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 08:46 PM #4
Thanks for the info guys...I figured as much. Maybe Ill get lucky and someone will want to trade. Does anyone have a good picture of them? It may be worth just fabricating a close proximity out of aluminum bar stock.
Id really like to do it the right way and have the holes welded up and then repaint the roof....then you go down the rabbit hole of while you're repainting the roof, why not the whole truck....in a different color.....
Old 01-05-2022, 09:00 PM #5
Found this pic...looks like you could fab something similar out of 1/4" aluminum bar stock. Shape the ends, counter sink the holes and use some nice stainless button head bolts. Paint or powder coat as desired. I imagine it wouldn't be too hard to find a roll of rubber gasket material in the correct width and thickness.
Old 01-05-2022, 11:13 PM #6
gtojimbo's Avatar
Real Name: jim
gtojimbo's Avatar
Real Name: jim
it looks like the third hole on that strip is cracked, thats what happens to them over time. one of mine is cracked just like that and i put black silicone in it because i havent been able to find another good one.
Old 01-05-2022, 11:21 PM #7
Gotcha. Been doing a little research...I still need to go measure the factory roof rack rails for length and width, but you can also by aluminum half-round from mcmaster carr by the foot. Again, drill and counter sink some holes for button head bolts, and come up with a way to finish/shape the nose of both pieces, they could actually end up looking better than the factory blanks with a little bit of effort.
Old 01-06-2022, 12:14 AM #8
gtojimbo's Avatar
Real Name: jim
gtojimbo's Avatar
Real Name: jim
yea, i really like that idea!
Old 01-06-2022, 09:06 AM #9
yea, the hard part will be shaping the nose of each piece and you don't want to mess up as the aluminum isn't cheap!
Old 01-06-2022, 09:16 AM #10
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
30 mins with belt grinder and some patients would be pretty easy to make those round profiles.
if your sensibilities require CNC machining... then it's just more money but not hard to machine at all.
you could even use some fuel tank strapping and trim to fit for the rubber seal.
Old 01-06-2022, 10:03 AM #11
good point....I may order two small samples of half-round and bar stock....just to mess around and see which looks better.
Old 01-06-2022, 09:42 PM #12
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
I think I have a set of factory delete strips if you end up wanting to go factory.
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 01-06-2022, 10:49 PM #13
If you have a set of factory delete strips, Ill happily take them off your hands!!!
Old 01-07-2022, 02:06 AM #14
Uhzachary Uhzachary is offline
Uhzachary is on a distinguished road
I have these "delete" strips, granted I believe mine are like the picture you posted where its cracked. I am also located in Austin, so we could meetup and you can check it and possibly trade if you're interested. Shoot me a PM and maybe we can work something out
Uhzachary is offline   Reply With QuoteReply With Quote
Old 01-07-2022, 08:59 AM #15
PM sent
oem , panels , rack , roof , trade
FS:3rd Gen OEM Roof Rack Delete strips, $25 Arkansas 78f150tx For Sale: T4R Items 1 09-08-2020 12:26 AM
FS: '01/'02 Taillight Harnesses, Roof Rack Weather Strips, Delete Strips-Kansas City ToyotaBrah For Sale: T4R Items 0 09-05-2020 01:48 PM
Roof rack delete strips 93toy 3rd gen T4Rs 12 09-20-2019 02:47 PM
WTB 3rd gen roof rack "delete" strips 2002tii Want to Buy/Trade 0 11-20-2012 03:01 PM
TRADE: Silver roof rack for Black roof rack. trijicon Classifieds - buy & sell (no commercial ads please) 0 04-19-2006 02:38 AM
