Old 03-11-2023, 01:55 PM #196
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Have you gotten enough seat time with new 5th gear to determine if juice is worth the squeeze?
Inquiring minds wana know.
Old 03-11-2023, 02:38 PM #197
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
If I were doing more interstate driving I would definitely keep the 5th gear ratio. I went to Little Rock and back last weekend (roughly 150 miles round trip) and averaged 22.0 mpg while doing 70-80 mph. Most of my driving is in the 40-50 mph range and the new 5th gear ratio is useless in that mph range with my current tire size and differential gear ratio (4.10). I think the 5th gear swap is really for people running larger tires and deeper gears that want to lower their highway rpm’s in 5th gear. 33’s/4.88 or 35’s/5.29 would be the minimum I would recommend for the 5th gear swap.
Old 03-11-2023, 02:39 PM #198
Real Name: Patrick
Real Name: Patrick
Here’s a couple pics of the display (hopefully). The photos make it seem about 50 percent brighter than what it really is.
Old 03-11-2023, 05:50 PM #199
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I like that thermometer. I hope I can make something to make it fix by my rear view like the newer tacumas and 4 runners.
Great Job @badluck .
Old 03-12-2023, 10:57 AM #200
Real Name: Mark
Real Name: Mark
That's how it goes sometimes with Mod's now you know. Hwy mpg's are nice, you going 33's or 35's.
Doubt you have a problem flipping it if you choose.
Old 03-12-2023, 11:30 AM #201
Real Name: Patrick
Real Name: Patrick
I’m staying with stock gearing and 265/70R17’s for a while. Fixing my house is my main priority for the foreseeable future. I’ve got something in the works to hopefully rectify the situation.
Old 03-16-2023, 08:37 AM #202
Real Name: Mark
Real Name: Mark
I feel for you fixing-up a house in this market daammn. Was fortunate in finishing my project now in 20.
Old 04-02-2023, 12:19 AM #203
Real Name: Patrick
Real Name: Patrick
I’ve been chasing oil leaks since I bought this 4Runner at the end of 2021. I’ve done valve cover gaskets/half moons/cam plugs, replaced the rear main seal during a transmission/flywheel/clutch replacement, and resealed the oil pan. Thoroughly cleaned the engine after each repair, but the oil leak persists. I finally had some time to do another thorough engine degreasing and added oil dye to make sure if I missed anything during clean up that a new leak would be more obvious.
Anyways, I’ve finally narrowed down the location of my engine oil leak. I’ll attach some photos of it but for context it’s the passenger side of the engine block starting about 1/2” below the mating surface for the cylinder head and about 1” from the rear of the engine. I’m 99 percent sure my engine block is cracked. I can clean it off, start the engine, and watch it get wet with engine oil again.
I used an inspection mirror and borescope and verified it’s not coming from the head gasket or the back of the passenger head or block
Old 04-02-2023, 07:53 AM #204
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
No way a cracked block?
Old 04-02-2023, 10:09 AM #205
Real Name: Mark
Real Name: Mark
Good discovery work now you know, I'm sure it not what you wanted to find.
Old 04-02-2023, 11:31 AM #206
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
A little high heat jb wled and it'll be like new!
That really sucks though.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 04-02-2023, 12:14 PM #207
Real Name: Patrick
Real Name: Patrick
I might give it a shot, but I’ve never had any luck trying to fix cracked blocks. Even tried welding a cracked block on a friend’s Jeep 4.0L one time and it just recracked in the same spot a few months later. It’s just free rust proofing at this point lol I doubt I’ll do anything until it’s time to do a timing belt or head gasket.
Not really what I wanted or thought I would find, but at least I finally found it.
It sure looks that way. I saw a few posts on Tacoma world last night when I was looking for better photos of that side that had cracked 5VZ blocks.
Old 04-02-2023, 07:16 PM #208
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
I'm sorry to hear this bro. So, with you mentioning that you're probably not doing anything until a timing belt job or a head gasket job comes up, do you still plan to daily drive this thing? Also just curious, are you having to add oil in between oil changes? If so, approximately how much would you say?
Old 04-02-2023, 08:51 PM #209
Real Name: Mark
Real Name: Mark
I'm with @Twisted Sid was first thought, add if possible dental burr to crack V it out.
This worst case scenario for cast iron repair.
Old 04-02-2023, 08:54 PM #210
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
You can actually weld cast iron. The issue is you have to get it glowing red hot before hand.
4runner , case , transfer , transmission , work
Liquidmantis's modest [boring] build thread Liquidmantis 5th gen T4Rs 134 05-24-2023 10:17 AM
JR's basic boring "build" - dog hauler and ski transport 99blkx 3rd gen T4Rs 20 05-11-2021 11:41 AM
