Old 04-02-2023, 10:23 PM #211
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by JoeT4R View Post
I'm sorry to hear this bro. So, with you mentioning that you're probably not doing anything until a timing belt job or a head gasket job comes up, do you still plan to daily drive this thing? Also just curious, are you having to add oil in between oil changes? If so, approximately how much would you say?
I change my oil every 4000 miles, and check the level every 1000 miles. I’m assuming that it’s been cracked my entire ownership, and I’ve never had to add oil between oil changes. I’m going to keep driving until either the timing belt/head gasket/head needs repair or the oil leak gets worse. I’d say it’s only about 3/4 quart of oil lost every 4000 miles, but the thing with oil leaks is 1 quart of oil can cause a huge mess. I’m really living up to my name here lately. Just some really bad luck lately.
Old 04-02-2023, 11:56 PM #212
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Originally Posted by brillo_76 View Post
The issue is you have to get it glowing red hot before hand. .
Add maintaining that heat through laying of beads, rate of cooling, stress relief peening, matching nickel content.
Cast Iron sucks
Old 04-03-2023, 12:08 AM #213
HiLife HiLife is offline
Could be when the transfer case let go violently...it stressed the block and cracked it?
Either way that's a let down. To discover that the block is damaged.
The funny thing is I feel my 4runner hates me, I fix one thing, and 2 other stuff breaks.
Old 04-03-2023, 12:20 AM #214
Real Name: Mark
Real Name: Mark
Probably a bad Monday or Friday for person measuring n mixing cast iron ingredients
Old 04-03-2023, 06:17 AM #215
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Interesting. That's not horrible, but it would be nice if no oil was lost of course. You think you'd consider a JDM engine for a replacement? Would you be up for the task of that? Or are you not even there yet mentally?
Old 04-03-2023, 08:42 AM #216
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
That's what I expect happened. The transfer case damage possibly caused this. As i never heard of cast iron block failing on a Toyota that didn't suck in water or have a major injury.
Old 04-03-2023, 08:44 AM #217
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I just keep an eye on it and run it. As you said it's been there since you owned it. Can't be too bad. :]
Old 04-03-2023, 08:58 AM #218
Real Name: Patrick
Real Name: Patrick
When the transfer case exploded it cracked the transmission (no surprise there). It also cracked a mounting boss off the engine so I’m not surprised the block cracked.
Old 06-26-2023, 01:51 PM #219
Real Name: Patrick
Real Name: Patrick
6/24/2023 213406 miles
-Replaced transmission with another new OEM transmission with original 5th gear ratio
-Applied QuikSteel to engine block crack while transmission was out
I decided to go back to the original 5th gear ratio due to reduced drivability. While the new 5th gear ratio was great for interstate/highway cruising rpm's (65-85 mph) it was pretty much unusable if I had even an empty trailer at those speeds.
Applied QuikSteel to the leaking engine block crack while the transmission was out. I originally planned on removing the passenger exhaust manifold to get to it and purchased the necessary gaskets, but after removing the transmission (and starter) I was able to blindly prep the are with the help of a right angle die grinder, burr bit, lots of sandpaper, and a spotter mirror. QuikSteel was highly recommended by the internet (lol) for repairing cracked engine blocks. It was not easy to work with. After mixing it was the equivalent of brake shavings mixed in a thin epoxy. It didn't want to stick to the block and preferred to stay on my glove during application. I kept working with it and thankfully it started to thicken up and somewhat cooperate with me enough to get a thin layer over the crack. I've checked on it a couple times in the last 30 miles and haven't seen any oil residue so hopefully it stays that way. *knocks on wood*
Old 06-27-2023, 02:05 AM #220
amalik amalik is offline
amalik is on a distinguished road
I hope it stays repaired.
My VCG are puking oil all over the area. What's the most effective cleaning agent for the oil stains since you went through this already, purple power?
amalik is offline   Reply With QuoteReply With Quote
Old 06-27-2023, 10:36 AM #221
Real Name: Patrick
Real Name: Patrick
I use brake cleaner, but I also work in a shop so I don't have to buy it. Might be quite expensive going that route.
Old 08-12-2023, 10:45 AM #222
Real Name: Patrick
Real Name: Patrick
8/11/2023 214635 miles
-LOF with synthetic 5W30 and OEM filter
Old 08-12-2023, 11:17 AM #223
JoeT4R's Avatar
JoeT4R's Avatar
Funny, I'll be doing an oil change tonight after I get home from work. I'll roll over to 330K on my way home this evening.
Old 01-08-2024, 11:21 AM #224
Real Name: Patrick
Real Name: Patrick
1/1/2024 218858 miles
-Rear axle seals, bearings, retainers $140
-Rear drums, shoes, hardware/springs $200
-Rear diff fluid $FREE
4runner , case , transfer , transmission , work
Liquidmantis's modest [boring] build thread Liquidmantis 5th gen T4Rs 134 05-24-2023 10:17 AM
JR's basic boring "build" - dog hauler and ski transport 99blkx 3rd gen T4Rs 20 05-11-2021 11:41 AM
