Old 01-05-2022, 05:41 PM #1
Bchavers Bchavers is offline
Bchavers is on a distinguished road
1st gear
Hello again. My 2001, 4runner, when I come to a stop, the trans doesn't shift to 1st. I have to shift into neutral or reverse then shift back to Drive. To get into 1st. Or I can hit the accelerator and with a gnarly thud as the trans drops to 1st, the truck moves forward.
Bchavers is offline   Reply With QuoteReply With Quote
Old 01-05-2022, 05:53 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Dirty screen filter, dirty fluid, bad solenoid and or transmission failing.
When was the last time the fluid was exchanged . Screen filter replaced and the pan magnets cleaned?
I believe the solenoids control the shifting. Never a good thing if the transmission is not shiting properly
What's the transmission fluid level?
Old 01-05-2022, 06:01 PM #3
spartacus's Avatar
spartacus's Avatar
Your line pressure might be low. You have electronic control versus the earlier year kick down cable. If you have access to the FSM there might be a procedure. Hopefully some one with a 2001-2002 can help.
Old 01-05-2022, 07:44 PM #4
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Yes, there's two solenoids that control all gear shifts and a third for torque converter lockup. Bad fluid or lack of flow due to clogging could create these symptoms.
326WHP 347TQ
Old 01-05-2022, 09:02 PM #5
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
What happens when you shift into low gear when this occurs?
Old 01-06-2022, 11:22 AM #6
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
This^
What happens when you manually shift down to L? Does it go into 1st? If it does, that it could be the solenoid, clogged filter or low/bad fluid.
If it still doesn't downshift, something mechanical is messed up in the tranny.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 01-06-2022, 02:16 PM #7
This is a stretch, but, what is your TPS at idle cold and hot? I agree on the solenoids however…..
If your TPS changes when the TB warms up I can see the PCM thinking your still depressing the throttle pedal
1st , drive , gnarly , shift , trans
Review: East Coast Gear Supply Gear Swap comtn4x4 5th gen T4Rs 27 09-20-2021 07:57 PM
4runner Doesn't know it's in Gear, Gear Selector in Dash Not Lit, VSC goes off the_josh 4th Gen T4Rs 2 01-26-2021 01:35 AM
Nitro Gear 4.56 ReGear - Why the different Gear Oil??? 007Tacoma 5th gen T4Rs 10 01-19-2021 04:57 PM
Gear shifter really hard to move/shift into gear (auto trans) infamousRNR 3rd gen T4Rs 7 07-03-2018 03:42 PM
Gear Oil to Prevent Gear "whine" - suggestions? BIG 4th Gen T4Rs 5 11-18-2010 11:54 AM
