Old 01-08-2022, 09:37 AM #1
jonnyd42 jonnyd42 is offline
jonnyd42 is on a distinguished road
Snap ring setting for 5100 + 880/906 coils
I bought the set from srq, under the impression I'll be able to get a minor lift while also correcting the sag. Hoping for about 1-1.5" in the front and 2-2.5" in the rear.
From reading other threads looks like folks are setting the ring to the lowest setting, but with varied results.
Just wanted to confirm to hopefully save myself some work! Where should I set the ring?
jonnyd42 is offline   Reply With QuoteReply With Quote
Old 01-08-2022, 11:36 AM #2
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
I’m running 5100s on the lowest perch with 880/906. Check out my build thread for before/after measurements and photos (link in my signature).
I got about 1” lift in the front and 2.25” in the rear (but the rear will likely settle down to 2”). I also replaced nearly every bushing on the truck with poly. That is just about perfect for me. Mild lift with some forward leaning rake when unloaded.
The amount of lift you’ll get depends on several factors.
- Factory weight? Or aftermarket armor?
- Also replacing bushings (including body mount bushings)? Or leaving old compressed bushings?
- How saggy is your original suspension?
- What year is your truck? ‘99s sat taller than some other years, so if you have a ‘99 then you’ll likely see less lift.
- Probably other stuff I’m not thinking of.
https://www.toyota-4runner.org/3692675-post39.html
https://www.toyota-4runner.org/3694270-post40.html
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 01-08-2022, 12:14 PM #3
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
Bilstein sends a chart with the shocks. On my 99’ the 2” front 6112 setting was perfect to match up 2906 coils in the rear.
If your wanting more of a rake, just go down in the front.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
folks , ring , set , setting , snap
TRD coils/5100 on lowest setting + 890's? lgc285 3rd gen T4Rs 1 05-16-2020 06:24 PM
COM10T Snap Ring Size Johnny4runner 5th gen T4Rs 1 04-13-2020 12:49 PM
Which snap ring setting for 4Runner specific BS 5100 with OEM springs in front? calnhob 3rd gen T4Rs 10 01-12-2018 10:33 AM
Bilstein 5100 Snap Ring Failure lewisp 3rd gen T4Rs 24 03-18-2016 05:50 AM
Snap ring pliers TJM 3rd gen T4Rs 4 02-28-2014 06:21 PM
