Old 01-08-2022, 03:56 PM #1
beefsix beefsix is offline
beefsix is on a distinguished road
Rear axle f*ckery
** SOLVED **
Problem: Rear axle shaft bolts did not line up with bolt holes. Fit in perfectly when turned 15 degrees CCW.
Solution: Hammer on bolt studs with 3/4" Brass Drift Punch until bolts grabbed onto holes and came free of snag. Fit in perfectly after.
** SOLVED **
Hey all, trying to replace my rear axle seals. Took my rear axles to a shop to replace bearings, etc. putting them in today. My passenger side axle goes in smoothly, albeit with a tiny touch of gap that I’m hoping the bolts will snug up (1st attachment).
The problem lies on my drivers side rear axle - it snugs up PERFECTLY….when the bolts aren’t lined up properly (2nd attachment). Won’t seat in when they are (3rd attachment). So what gives? Did I mess up the inner seals?
Any help is greatly appreciated. Thanks.
Rear axle f*ckery-790cfccc-fe85-462e-b9a9-0cee4f612401-jpg  Rear axle f*ckery-90d7dbc7-5a9f-446f-ac59-5c15244fe19f-jpg  Rear axle f*ckery-f5985c99-2235-4896-ba6d-eebd2e33cc19-jpg
beefsix is offline   Reply With QuoteReply With Quote
Old 01-08-2022, 04:50 PM #2
bmason8159 bmason8159 is offline
bmason8159 is on a distinguished road
The shop could have put the bearing on wrong
bmason8159 is offline   Reply With QuoteReply With Quote
Old 01-08-2022, 05:16 PM #3
I don't know how much that would have to do with it though - it's a perfect circle, so orientation shouldn't matter, right? Especially if it seats up perfectly when the bolts are just turned to the left 15 degrees. I could be wrong.
Old 01-08-2022, 05:19 PM #4
rexassian rexassian is offline
rexassian is on a distinguished road
Have you tried rotating the axle flange so that the splines align into the carrier? The gap on your passenger side is fine and should go away once you tighten the nuts.
1999 SR5 V6 manual trans 4x4 - Lifted on 35's - Build thread
rexassian is offline   Reply With QuoteReply With Quote
Old 01-08-2022, 05:25 PM #5
how i do dat
many job and hobbie involve use of helmet, need hand hold ty
Old 01-09-2022, 03:04 PM #6
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Grab your driveshaft and turn it so the splines on axle can align with those inside.
Old 01-09-2022, 05:01 PM #7
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
@fourfive wasn’t this what happened when you did your rear axle seals? If I remember right one bearing wasn’t entirely seated in the retainer.
JZiggy is offline   Reply With QuoteReply With Quote
Old 01-09-2022, 09:14 PM #8
Originally Posted by beefsix View Post
how i do dat
Hold the bearing cup and rotate the lug studs/axle shaft.
Old 01-10-2022, 12:12 AM #9
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Looks & sounds almost identical to my situation. Correct, the bearing wasn't seated far enough into the housing. I turned the axle shaft vertical & lightly slammed the splined end into a piece of wood on the ground which seated the bearing deeper into the housing & everything bolted up perfectly after that.
See 30m 17s - 31m 8s in @mtbtim & @infamousRNR video.
Toyota Rear Axle Seal/Bearing Replacement (ABS Rearend) - YouTube
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 12:54 PM #10
Right on ya'll thanks for the ideas. Unfortunately neither the wood drop nor the driveline rotation worked. Still gets hung up at the same spot. I called the shop and they said to bring it on back. Here's hopin
Old 01-10-2022, 01:01 PM #11
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
What happened to the shroom on the end of shaft?? Want that you
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 01-10-2022, 01:34 PM #12
fourfive's Avatar
fourfive's Avatar
Did you visually check/measure if the bearing is fully seated the same distance within the housing on both sides?
Also make sure that the studs are fully seated.
Here's a picture I took when I was trying to troubleshoot a similar issue I had. I put a straight edge on the studs and measured that distance to the ABS ring. You can see the subtle difference in the amount of the ABS ring above the straight edge. May be worth checking that distance to see if there's a difference.
Old 01-10-2022, 01:44 PM #13
fourfive's Avatar
fourfive's Avatar
Also take measurements to make sure you have the same amount of polished axle showing to rule out issues with the press work and compare the press work on the seals to make sure they are properly seated.
Old 01-10-2022, 02:32 PM #14
@fourfive I'll check those while I wait for my buddy to _pick me up and take me to the shop_ (this is getting tiresome, I need a second car!) :P
Old 01-10-2022, 08:20 PM #15
Got it back in. One bolt was a little "lazy" and needed some encouragement from my new friend, 3/4" Brass Drift Punch.
attachment , axle , bolts , rear , side
Rear Axle Seal: Axle Puller Tool Design nobb 3rd gen T4Rs 29 11-23-2019 07:39 AM
WTB: Philadelphia- Non rusty 3rd gen rear axle of rear axle cover 4:10 Temple90 Want to Buy/Trade 0 05-14-2019 12:34 PM
Rear axle/suspension problem-axle shifts when going on/off the gas Rusty Plum 3rd gen T4Rs 7 09-07-2014 09:46 PM
