I think I already know the answer to my question, but just double checking with ya’ll.
On cold weather cold starts (<25*F cold starts) I get some condensation coming out the tail pipe. But today the condensation in the exhaust system revealed a leak. The leak is in the last joint after the muffler.
Question:
There’s no reason to fix this, right?
I’d like to eventually install all new cat back, something like the Magnaflow Overland series, so I’d rather not mess with my old worn out and rusting out exhaust until I’m ready to replace it all, if I can help it.
In the photo, you can see a water droplet at the joint, and the water that has dropped and splashed onto the rear sway bar and diff.
(Unrelated, but just in case someone asks: that yellowish waxy stuff is 3M Rust Fighter-I Cavity Wax that was sprayed all up inside the nooks and crannies, after all the blasting and POR-15.)
Thanks!!
