Old 01-24-2022, 12:23 PM #16
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
Originally Posted by Spiker Engineering View Post
Haha, "$100 toe-and-go" - that's basically what it is!
I made the adjustments with the truck resting on the ground (one advantage of having a lifted truck).
I have the AccuLevel with the wheel mount Amazon.com: Longacre(R) 52-78298 Digital C/C Gauge, AccuLevel/QuickSet : Automotive., makes the process much easier -
Pls stop spending my money.
Any trouble making the adjustments with weight on the wheels? I've heard of people "borrowing" trays from fast food restaurants and sticking them under the tires to reduce friction.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 01-24-2022, 01:27 PM #17
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
It wasn't too hard to rotate the cams, I sort of "helped" the movements by pushing on the tire in the needed direction. But I can see having trays or cardboard pieces underneath to help things along.
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 01-24-2022, 05:01 PM #18
I was able to make changes on the ground too. To check things, you would want to roll it forward and back a bit to relieve any leftover forces on the tires/bushings.
You generally want to bias your cross-camber and cross-caster with the right side being more negative (about 0.2* for each) which counters road crown a bit without causing any L/R wear imbalances.
0.4* cross-camber isn't great, but 0.2* is fine. Also, coming from a mostly car background, I can't wrap my head around near-0 camber... I haven't had a car with less than 1* camber F+R rear since about 2000. Trucks be trucks though.
Otherwise, good job getting it right!
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-28-2022, 11:39 AM #19
official vendor
official vendor
Thanks Charlie! I view it the same way - it's a truck, not a refined sports car; it drives perfectly fine by my standards; the alignment numbers are looking good enough; => call it done and move on to other things to obsess over
alignment , caster , numbers , spec , ucas
JBA UCAs, Clearance & Alignment lpittman 5th gen T4Rs 25 11-21-2021 07:16 PM
School me on Alignment and UCAs FamousAv8er 5th gen T4Rs 2 05-22-2018 02:44 PM
My Alignment Results w/o UCAs Hoover Dam 5th gen T4Rs 6 02-08-2018 12:15 AM
Need Alignment Help - Lifted w/ LR UCAs ugamurph 3rd gen T4Rs 10 11-28-2013 10:43 PM
Toytec Ultimate Lift Kit: UCAs or not to UCAs... W8kbrder 5th gen T4Rs 35 09-15-2013 10:23 PM
