Old 01-12-2022, 09:43 PM #31
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Good information. I probably go to these valves with short hoses. I am curious if the 2nd gen Tacoma oil filter relocation kits will fit our 3rd gens? If they would. We could move the oil filters to the top of the engine and s run another house down through the skid. This would fix the oil spill issue from its current filter location.
Old 01-12-2022, 10:09 PM #32
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I mean I'm definitely not familiar with Tacomas, but from the little I do know I don't see why they wouldn't. It may not line up as perfectly as intended but it should absolutely thread on and seal up to the housing. From there it would just be mounting which can always be solved with hose lengths and brackets...
Old 01-13-2022, 01:15 AM #33
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Not sure. My 2009 tocums sport TRD came with a factory oil filter relocation. I bought it brand new. Being I use the sane filter on both. I figured they may be retrofitted to our 3td gens. As it's OEM factory I figured it's quality is alit better then the aftermarket. It's just a thought..
Old 01-13-2022, 01:32 AM #34
zameul40's Avatar
zameul40 zameul40 is offline
zameul40 is on a distinguished road
zameul40's Avatar
Yes this is why i refuse to have anyone EVER change the oil in any of my vehicles. A lot of people do not care about the quality of their work.
zameul40 is offline   Reply With QuoteReply With Quote
Old 01-15-2022, 10:30 PM #35
cruisectrl cruisectrl is offline
cruisectrl is on a distinguished road
Originally Posted by Endlessblockades View Post
Cool. I became aware of these in a weird way - via a snail-mailer from my city offering a free Fumoto valve to reduce oil spillage into the gutter/storm drains for people doing oil changes in the street. Must have been targeted by zip code LOL. Used in on my 2nd Gen and bought one for my 3rd gen when I sold the 1991. No more issues with stripped plugs, messy draining, buying washers, etc. Set it and forget it. I'd like one on the transmission, too, but I don't think they make one with the correct thread pitch/depth/size or something.
Edit - to make matters worse (for purists), I'm running a K & N oil filter that I believe is "good for at least 10,000 miles" I won't wait that long, but I like that they have a 1" nut on them for easy removal.
I second both of these things. Have had these valves on both my RAV4 and 4R for for a combined 7 years and have never had an issue--I'm not a rock crawler though. The only complaints I have are that the pan drains reeeeally slowly if the oil isn't warm, and that I'm not positive it lets everything out without removing the valve entirely which kind of defeats the purpose... I change my oil every 3-5k with full synthetic so I'm hoping there isn't too much sludge that's collecting in there. Next oil change, I'll probably just remove the valve entirely once it seems to be done draining to be sure--might be something I do every few oil changes.
I've also use those K&N filters but I swap em with every oil change which is probably overkill... I stopped buying them from Amazon since a lot of folks have reported being sent counterfeits.
Now if only someone could up with a solution to the oil spilling everywhere when I unscrew the filter...
cruisectrl is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 02:55 PM #36
Form-a-funnel, right under the filter. Leads the oil to drip right down to a pan, no drips on the diff, frame, skids, etc.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-17-2022, 03:21 PM #37
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
[QUOTE=phattyduck;3704233]Form-a-funnel, right under the filter. Leads the oil to drip right down to a pan, no drips on the diff, frame, skids, etc.
-Charlie[/QUOTE
2X……Form-a-Funnel is excellent, saves the day on many of the vehicles I change oil on.
Zero mess!
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 01-20-2022, 10:49 PM #38
I'm so glad this forum exists. Thank you! I've been dropping my skids every time I change the oil because the oil dripping and pooling wherever it wants drives me nuts.
engine , parts , performance , recommend , replaced
Destroyed Engine mindavion 3rd gen T4Rs 55 07-17-2018 03:45 PM
06 4runner engine completely destroyed! Is it even worth fixing? nalbertasr5 4th Gen T4Rs 16 04-10-2018 10:36 PM
Help Needed to Save the Beast- Engine Overheated & Destroyed?!? georgeecfc 3rd gen T4Rs 15 08-18-2015 12:35 PM
parting out '88 (engine and hood all destroyed) good everything else cait Classifieds - buy & sell (no commercial ads please) 14 04-05-2011 08:05 AM
