Old 01-25-2022, 02:17 PM #16
spartacus's Avatar
spartacus's Avatar
Originally Posted by Barnabas1 View Post
Update: I rotated tires and the issue seems to have gone away, which points to a bad alignment. I plan to rotate them back, get it aligned, and verify this solves my problem, will update further once this is confirmed.
Check the tires for uneven wear.
Old 02-25-2022, 04:15 PM #17
Barnabas1 Barnabas1 is offline
Barnabas1 is on a distinguished road
Originally Posted by Bad Luck View Post
How does rotating the tires lead you to believe the alignment is the issue?
I have one bad tire on the passenger side with worn out inner tread, since my symptoms seemed like they were gone with this tire on the front I thought maybe my camber or caster was off. But I did get the alignment checked, and the shop said the alignment was good.
I am thinking I just have less traction with the worn out tire, so the symptoms are less noticeable than with the new tire.
Barnabas1 is offline   Reply With QuoteReply With Quote
Old 04-30-2022, 11:58 PM #18
Update: My rack bushings were toast and I replaced them, but it did not solve my 4wd issues. My best guess is maybe the control arm bushings, but I have not troubleshot this at all yet. With winter being over and rust winning the battle on my frame I may or may not go after this repair if I deem them to be bad. I will update the thread further if I make any progress on this. Thanks for all the help so far.
2wd , 4wd , coming , front , present
03 Limited Battery light comes on intermittently nayborbob 4th Gen T4Rs 3 03-31-2018 08:53 AM
2015 Limited Pulls Left- Help! rennur 5th gen T4Rs 15 11-10-2016 06:39 PM
97 intermittently pulls to the left... Vesper 3rd gen T4Rs 4 02-23-2014 05:56 PM
Steering jerks HALFDZNROSES 3rd gen T4Rs 3 08-19-2011 03:27 PM
Jerks when accelerating 75206 3rd gen T4Rs 3 03-29-2010 09:11 PM
