Originally Posted by Bad Luck
How does rotating the tires lead you to believe the alignment is the issue?
I have one bad tire on the passenger side with worn out inner tread, since my symptoms seemed like they were gone with this tire on the front I thought maybe my camber or caster was off. But I did get the alignment checked, and the shop said the alignment was good.
I am thinking I just have less traction with the worn out tire, so the symptoms are less noticeable than with the new tire.
