Old 01-17-2022, 08:55 PM #1
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Corrosion on the vacuum brake booster near the master cylinder
Previous owner had the brakes done about two years ago. Fluid exchanged during frame swap a few months ago. No symptoms, no leaks, brakes feel great.
Today I noticed this corrosion on the vacuum brake booster near the master cylinder. Nothing is wet. It looks old. I just never noticed it before for some reason.
Thoughts? Maybe from a previous leak that has been repaired?
EDIT: clarified the location of the corrosion
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 09:00 PM #2
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
I'm thinking they spilled some brake fluid and didn't bother to clean it up. Brake fluid will eat through paint like nobody's business, and it appears to have left a trail where it ran down and dripped off. A leak would be possible in this regard I suppose. Just my opinion
If nothing is wrong I'd just try and brush it up, spray some rust reformer on it and call it good
Old 01-17-2022, 09:04 PM #3
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
Take a wire brush to it to see if it's just a paint issue as Devbot said.
That's the vacuum brake booster btw.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 01-17-2022, 09:38 PM #4
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Verify your grommets are not seeping. I have one that had the grommets between the master cylinder and the brake fluid reserve tank. This leaks back to the vacuum booster then eats the paint off as it leaks down to the ground.
If it's grommets are seeping you see pooling under the tank on the master cylinder. May not be what is going on but worth taking a peak.
Old 01-18-2022, 07:14 AM #5
cahilc cahilc is offline
cahilc is on a distinguished road
Everything mentioned above... Plus...
Clean it real good before painting. Chemical neutralizes or physically neutralize (sandpaper). Brake fluid cuts down to the metal and gets into the metal surface. That's why it's such a bane especially on an exterior surface. Once bubbled needs to be aggressively removed or will rebubble with the new paint.
It'll clean up real nice and look great. Just know you have to be real aggressive or it will pop back up again.
2002 Sport Edition (Big Red) 2wd auto, 235k
cahilc is offline   Reply With QuoteReply With Quote
ago , brakes , corrosion , master , noticed
ABS master cylinder to one ton master swap? dennisuello 3rd gen T4Rs 3 07-16-2018 07:02 PM
Slave cylinder or master cylinder? That is the question. ieatelk Classic T4Rs 8 07-14-2012 04:54 PM
master cylinder berman 72 Classic T4Rs 11 02-07-2011 06:00 PM
Master Cylinder, Slave Cylinder Issue bomhour Classic T4Rs 6 01-10-2010 09:14 PM
