Old 01-19-2022, 01:00 PM #1
BRTrubo BRTrubo is offline
BRTrubo is on a distinguished road
'97 SR5 3rd Gen power lock parts query
Hello all!
I have a '97 SR5 - last summer the push rod and internals in the driver's door finally gave up the ghost and the handle wouldn't open from the inside. I got that sorted before winter but my mechanic found most of the assembly including the lock solenoid was worn out.
He got some parts from a donor car but it had a different lock solenoid - as a result everything except the power locks works. The current one apparently is missing a set of electrical connections to make it all work. I'd like to get those working again, but I don't know the part number or where to find one. My guy is pretty good but he's been having trouble sourcing one from Toyota (who frankly want me to give up my baby for a new car - fat chance!).
Does anyone know the part number and more importantly where to find one?
Thanks!
-Bernie
BRTrubo is offline   Reply With QuoteReply With Quote
Old 01-19-2022, 02:33 PM #2
Riceye Riceye is offline
Riceye will become famous soon enough Riceye will become famous soon enough
Actuator p/n 69120-35050
Lock actuator
Search Amazon with the part # if you deal with that evil empire. It's available and could be in your hands yet this week.
_________
2000 SR5 five speed. Everything works, even the antenna. No special mods; It's my canoe, kayak and dog hauler/winter beater.
I find that things usually go well right up until the moment they don't.
Riceye is offline   Reply With QuoteReply With Quote
Old 01-19-2022, 02:35 PM #3
I'll give that a go - thank you!
Old 01-19-2022, 02:38 PM #4
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
Originally Posted by BRTrubo View Post
Hello all!
Thanks!
-Bernie
I think your after 6904035150 LOCK ASSY, FRONT DOOR, LH
they don't make those no more. I would tell you your best bet is a pick'n'pull and just grab a drivers door off a 96-97. pretty sure(75% confidence rating) the 96-97 had the same door lock actuator assembly.
I will have to look but I think I might have a complete drivers door from a 97? maybe. BTW replacing that part is not a lot of fun.
edit: ok if that other part @BRTrubo referenced will work, go for it. looks like they are cheap and plentiful with that part number.
Old 01-19-2022, 02:46 PM #5
Yeah, I've been running into issues finding it too and was wondering if they weren't in production anymore. And I agree - it is NOT fun messing around in the door! If that part Riceye noted doesn't fit the bill I may take you up on that door...
Old 01-20-2022, 11:27 AM #6
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
one of the problems with the older parts diagrams is they never go back and update the diagram with the "supersedes" part number. I did check to see if that older part had other references but not hits for me... so I hope that newer part number works... please post back if it does. boots on the ground info is the best info.
Old 01-20-2022, 07:54 PM #7
Will do!
Old 01-30-2022, 04:42 PM #8
Well, it isn't the actuator - it's the assembly. Specifically, part #69040-35150: 69040-35150 Genuine Toyota Front Door Lock Assembly, Left
Anyone have any leads or ideas?
Old 02-22-2022, 10:13 PM #9
Pardon the thread bump - again, does anyone have part #69040-35150 or a lead on a replacement?
Old 02-22-2022, 10:57 PM #10
spartacus's Avatar
spartacus's Avatar
It's a little pricey but you can contact the seller and give him your old one and see if he can give you a break.
Toyota 4Runner OEM Front Left Driver Door Lock Latch Actuator 96-98 **Lifetime** | eBay
edit: Also Craigslist or FB market place and buy the whole door for about $100.
Old 02-23-2022, 12:40 AM #11
heat's Avatar
heat heat is offline
heat will become famous soon enough heat will become famous soon enough
heat's Avatar
That appears to be the door lock mechanism with the actuator. The door lock
mech on its own appears to be 69320-35210. But both are discontinued in the
US. Amayama, at least, lists it at $94, $24 shipping.
'02 Limited 4x4 AT - Stock ~181k miles
Thundercloud aka metallic dirt
heat is offline   Reply With QuoteReply With Quote
Old 02-26-2022, 06:35 PM #12
I'll check these out, thank you both!
car , lock , number , part , solenoid
FS: Power Door Lock Actuator with Lock Latch - rear passenger side T4RTX For Sale: T4R Items 4 06-26-2014 02:58 PM
Online OEM Parts Sources Query anthonym Maintenance/Detailing 4 09-15-2009 09:45 PM
Power lock going out skywalker1020 3rd gen T4Rs 2 05-21-2009 05:43 PM
'03 SE power lock problems kroney70 4th Gen T4Rs 2 02-07-2009 11:42 AM
Power lock question formulaz Classic T4Rs 1 05-17-2005 12:23 AM
