07-08-2021, 01:45 PM
JBA Offroad Upper Control Arm Install
are you guys getting tired of our videos yet?????
VIDEO
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
07-08-2021, 02:12 PM
Real Name: Devan
Real Name: Devan
I think it goes without saying your guys' channel is one of the most appreciated assets on here
Y2K Highlander
Millennium Silver 3.4L auto @ 320k and climbing
07-08-2021, 10:04 PM
Real Name: Jarrod
Real Name: Jarrod
T4R folks will never tire of your guys’ videos. I like that JBA added a threaded hole for the ABS bracket, my set from a couple of years ago doesn't and has the bracket zip tied to the arm. One thing I noticed is that you torqued the through bolt while it was up on jack stands… On the UCA’s I’ve installed the instructions always mentioned to torque at ride height with the wheels installed.
96 5-spd w/E-locker, SS1.2 lift, JBA UCA’s, 1” BL, Other stuff
07-08-2021, 10:24 PM
Thanks for the informative video!
07-08-2021, 10:44 PM
Originally Posted by
Breaker Bar
Since the UCA bushings are fully floating it doesn’t matter their position when the bolt is torqued. A rubber bushing is bonded to the inner and outer sleeves so it’s neutral position has to be set at ride height.
07-09-2021, 01:22 AM
Real Name: Jarrod
Real Name: Jarrod
JZiggy
Good to know, I did see that the bushings in the vid are different than mine from 2018. The press in poly bushings with steel sleeve inserts on my JBA’s, as well as on my Readylift UCA’s that I installed on my Ram pickup stated to torque with the tires on the ground.
07-09-2021, 01:36 AM
Breaker Bar
looks like JZiggy beat me to the punch..
Devbot
thanks for the kind words guys. Tim and I were beginning to wonder if anyone on here watches our stuff anymore lol
Build Thread
07-09-2021, 08:34 AM
infamousRNR
I watch at least one of your videos most days! Lol
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
07-09-2021, 08:45 AM
Real Name: Devan
Real Name: Devan
infamousRNR
Literally every single repair I do I try to find something from you guys on the topic before I start
Y2K Highlander
08-22-2022, 06:36 PM
Any special considerations for getting the through bolt out of the passenger side?
"Bender" Silver 99 Limited with e-locker.
08-23-2022, 12:49 AM
Real Name: C8H18 Mike
BoomSticks
Watch Tim and Sean's video, you have to remove the airbox and loosen the AC lines. Passenger was easier than the driver side IIRC.
Sent from my Pixel 4 XL using Tapatalk
1999 Toyota 4Runner SR5 Sport 4WD, V6 5-Speed e-Locker->
4WD 4runner Journal Thread
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto ->
2WD 4runner Journal Thread
10-17-2022, 05:26 PM
octanejunkie
Yep, they didn't mention it, because there aren't any special considerations. I didn't have to move anything to get the passenger side bolt out.
12-01-2022, 12:41 PM
bringing this old thread back up, sorry.
Anyone have any issues with JBA? Highly consider it but also considering SPC. Talk me into/out of one another.
RockAuto discontinued SPC so unable to get it cheaper.
12-01-2022, 01:15 PM
Real Name: Patrick
Real Name: Patrick
mac33
Mevotech branded SPC control arms are still out there. Google MEVOTECH CMS861193 and MEVOTECH CMS861192.
2000 SR5 V6 Manual 4WD
https://www.toyota-4runner.org/3rd-g...biography.html
12-01-2022, 03:17 PM
Real Name: Christian
mac33
When I did mine, JBA's didn't have adjustable caster like SPC, so I ruled them out and went SPC. No regrets. Maybe they are different now?
