Old 12-30-2022, 01:57 AM #1
nissanh nissanh is offline
Home made Seat Bottom "upgrade"
My wife uses the 4R to work everyday, I drive it once every month or so just to check any issues, engage 4wd etc., I've noticed the drivers bottom seat cushion is not level, the left side is lower than the right side: I have noticed this in the Hilux too. I fixed the hilux's driver seat few years ago and did the same for the 4runner.
The issue is the spring/steel wires on the seat bottom frame have cut into the sponge/cushion. The fix is to add a thin plywood sheet between the cushion and spring/wires. This made the seat bottom to rise up about 1/2 inch or so and improved the visibility due to the higher seating position. A bonus is now the window line on driver's door is below the shoulder, and has given a truck like driving experience!
Home made Seat Bottom "upgrade"-20221221_114740-jpg  Home made Seat Bottom "upgrade"-20221229_201832-jpg
1990 3L Diesel Hilux LN 106; 1973 Ford Cortina XL
1992 4AFE Toyota Sprinter AE 91 (aka Geo Prizm)
1997 5vzfe 4Runner 4x4 (aka Hilux Surf)
2000 2uzfe 100 Series Land Cruiser
2021 Tacoma TRD Off-Road 4x4 6-speed
Old 12-30-2022, 02:06 PM #2
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
you might like to drill some holes in the plywood to allow the foam to breathe.
otherwise, you'll end up with a sweaty butt even with the aircon on.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 12-30-2022, 05:02 PM #3
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
My fix consisted of 2 pieces of spare carpet floor mats (from VW and Toyota, in this case), shaped to fit inside the seat bottom side bolsters, covered by a thin cloth seat cover(which I use anyway). The Toyota OEM foam, which I bought a new copy of, was just way too soft.
pluton is offline   Reply With QuoteReply With Quote
bottom , drivers , noticed , seat , side
Manual Seat Bottom Swap to Power Seat Bottom SilverBullet8404 3rd gen T4Rs 1 05-11-2020 12:53 AM
window exterior bottom trim ("weatherstripping"?) sctrsk 3rd gen T4Rs 2 01-20-2019 03:33 AM
Body Mounts Cause "bottom out sound"? Twin Bridges Engines / Suspension / Wheels / Tires / Audio / Accessories 1 09-19-2014 11:09 AM
My home made "Basket" rack fishin4 3rd gen T4Rs 9 08-28-2009 07:05 AM
"Pinson" Seal Home replacement or Pro? Some1esle Classic T4Rs 4 09-13-2006 12:15 AM
