Old 03-03-2015, 04:25 PM #1
BamaDrewski BamaDrewski is offline
BamaDrewski will become famous soon enough
Rear Lift Strut Bushing Fix for $1.15
There have been a couple of posts about worn out lift strut bushings on the 3rd Gen lift gate. I called the stealership and of course, they only sell the bushings together with the high dollar lift struts.
I found an easy ($1.15 cost) solution.
Go to Lowe’s and look in the specialty fasteners section for nylon bushings. Pick up one ½ x .328 x 1 (Hillman brand) nylon bushing. Bring it home and if you have a set of PVC pipe cutters (hand held as shown in the attached pic) cut the bushing in half. (one half for each side) Remove the top pin from each lift strut, pull the top part off the bracket, insert one half of the nylon piece through the bracket hole, push the strut top back over, insert the pin and set the fastening ring. (See picture). This is an easy and CHEAP fix and should last for some time. It takes the metal-to-metal rubbing away from the top end of the strut!
Rear Lift Strut Bushing Fix for alt=.15-nylon-bushing-lowes-jpg  Rear Lift Strut Bushing Fix for alt=.15-top-strut-bushing-jpg
BamaDrewski is offline   Reply With QuoteReply With Quote
Old 03-03-2015, 05:22 PM #2
Do-boy's Avatar
Do-boy Do-boy is offline
Do-boy is on a distinguished road
Do-boy's Avatar
very impressed that you found the perfect ID, OD, and length!
Do-boy is offline   Reply With QuoteReply With Quote
Old 03-03-2015, 05:39 PM #3
zacattack20's Avatar
zacattack20 zacattack20 is offline
zacattack20 will become famous soon enough
I just did the same thing this morning.
'98 SR5 Converted to '01-'02 Sport Edition
Matte Blue Vinyl Wrap - Black Interior - Too Many Mods
Build Thread
Instagram: 98trd4r
zacattack20 is offline   Reply With QuoteReply With Quote
Old 03-03-2015, 06:05 PM #4
Thanks man. I have to contribute the ID and OD to sheer luck! It was also lucky that by cutting the one piece in half, it exactly fits in between the "forks" of the upper strut. For me, I always like something inexpensive that solves an issue. Let's see how long this fix lasts. As the package came with two pieces, all you have to do is cut the other piece in half and you have another repair if and when they wear out or go bad.....
I put StrongArm struts on from Amazon at $44 a pair. I think the local stealership wanted something like $142 PER STRUT........my last pair of StrongArm's lasted 6 years.......
Old 03-03-2015, 06:41 PM #5
RedSled's Avatar
RedSled RedSled is offline
RedSled has a spectacular aura about RedSled has a spectacular aura about
RedSled's Avatar
I did this same thing about 2 months ago, and has been working great.
RedSled is offline   Reply With QuoteReply With Quote
Old 03-03-2015, 10:00 PM #6
MountainBiker MountainBiker is offline
MountainBiker is on a distinguished road
Nice fix! I did something a little different, using a bronze bushing that has a flange. Bronze is softer than the steel mating parts, so it should last forever, but not as cheap as the plastic!
2000 Limited: Toytec Superflex, 255/85-16, Lil Skips gas tank skid, SaVage rear bumper and skids, BAMF Sliders
2006 SR5: FJC Coilovers +2", Toytec Superflex, 255/85-16
Sold: 2017 TRD OffRoad Prem (this rig was too nice for me!)
MountainBiker is offline   Reply With QuoteReply With Quote
Old 03-04-2015, 02:49 AM #7
Unner's Avatar
Unner Unner is offline
Unner is just really nice Unner is just really nice Unner is just really nice Unner is just really nice
Unner's Avatar
Nice fix, did something similar on mine. Those cutters are awesome aren't they? I use them all the time to get clean cuts on stuff like transmission lines and power steering lines.
Unner is offline   Reply With QuoteReply With Quote
Old 03-04-2015, 03:33 PM #8
thor999 thor999 is offline
thor999 is on a distinguished road
I did this twenty five years ago.
2001 SR5 4x4
thor999 is offline   Reply With QuoteReply With Quote
Old 03-04-2015, 03:35 PM #9
SoSoJeff's Avatar
SoSoJeff SoSoJeff is offline
SoSoJeff is on a distinguished road
SoSoJeff's Avatar
good stuff.... thank you
SoSoJeff is offline   Reply With QuoteReply With Quote
Old 03-04-2015, 03:54 PM #10
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Very nice ingenuity Bama Drewski. Nylon bushings can be used for many things. Now the money you saved by not going to the dealer can buy you some more Ceratec.
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 03-05-2015, 01:38 AM #11
Fastphin Fastphin is offline
Fastphin is on a distinguished road
Next project, hopefully I can remember this post.
01 Ltd 4x4. Bilstein 6112s front ICON uca, 5150 with OME 906 rear.
Fastphin is offline   Reply With QuoteReply With Quote
Old 03-05-2015, 02:36 AM #12
Wikano's Avatar
Wikano Wikano is offline
Wikano is on a distinguished road
Wikano's Avatar
Great minds think alike Did this a while ago too but I would also recommend side nylon washers as well, they definitely help with the the squeaky noises.
Rear Lift Strut Bushing Fix for alt=.15-008-jpg  Rear Lift Strut Bushing Fix for alt=.15-007-jpg
Wikano is offline   Reply With QuoteReply With Quote
Old 03-06-2015, 08:48 AM #13
LOL LittleCaesar.....I guess you just couldn't resist the Ceratec comment.....HAHAHA
Old 03-06-2015, 10:44 AM #14
I am curious how it is holding up so far. Considering the 5vz is easy on oil, I would imagine quite well.
The nylon bushings are good till about 275f, then they can start to melt.
Old 03-06-2015, 11:16 AM #15
Ceratec is holding up fine. I can't imagine any normal circumstance where my truck would reach anything near 275 degrees Fahrenheit unless of course it caught on fire....LOL
*Rear Upper Control Arms/Bushing ISSUE w/ Lift* MALPASSEDlokol Classic T4Rs 0 03-01-2015 04:12 AM
Help! How do you get the bushing off rear shocks? boostedprozac 4th Gen T4Rs 7 07-18-2014 09:59 PM
Rear Control Arm Bushing Help kpnavarro Classic T4Rs 7 01-20-2013 10:56 PM
OME 881 Coils-3" Lift Front Strut Assy w/KYB Gas-A-Just strut-3rd gen runner STRRAYNGE For Sale: Suspension/Wheels/Tires 7 04-30-2012 09:44 PM
