Old 01-23-2022, 09:44 AM #16
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Originally Posted by FD7683 View Post
Whine is heard when you start the truck and gets louder when turning the wheel.
Just removed the entire pump and discovered the O-ring destroyed due to installation. I already ordered the reman at NAPA and its ready for pickup..... Going to be replacing it anyways since the original had 230k.
EDIT: Decided i'm going to be rebuilding my factory pump with the rebuild kit and see what happens. I don't feel comfortable using the reman from NAPA and will be returning it tomorrow. Read a bunch of horror stories about the reman pumps not working as it should - sometimes right out of the box they don't work.
Thatís probably a good way forward if you can lay the truck up for a few more days as nothing beats OEM part.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 01-23-2022, 10:44 AM #17
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
My favorite method to bleed the power steering system requires a length of tube and a rubber cap/stopper. I drain the reservoir, remove the power steering fluid return line from the reservoir, cap the open port on the reservoir, and insert a length of clear tube into the power steering return line. Fill the reservoir, start the engine for only a second, refill reservoir and repeat as necessary until the fluid is new and there are no air bubbles. Itís similar to a transmission flush as you are using the pump to force new fluid through the system. Works like a charm on every vehicle Iíve ever done a pump/rack/line on. Pretty much the only way to get all the air out of the power steering system in some gm vehicles.
Old 01-23-2022, 01:05 PM #18
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Originally Posted by Bad Luck View Post
My favorite method to bleed the power steering system requires a length of tube and a rubber cap/stopper. I drain the reservoir, remove the power steering fluid return line from the reservoir, cap the open port on the reservoir, and insert a length of clear tube into the power steering return line. Fill the reservoir, start the engine for only a second, refill reservoir and repeat as necessary until the fluid is new and there are no air bubbles. It’s similar to a transmission flush as you are using the pump to force new fluid through the system. Works like a charm on every vehicle I’ve ever done a pump/rack/line on. Pretty much the only way to get all the air out of the power steering system in some gm vehicles.
I used this method to flush the old fluid out but I can re-flush again if air won't leave the system using the Toyota service manual instructions. Ordered the rebuild kit on Amazon yesterday so most likely the truck will sit for 1 week. Not really a problem.
2000 4Runner Limited 4x4 V6
Old 01-23-2022, 01:26 PM #19
Real Name: Patrick
Real Name: Patrick
Interesting. I guess the o ring you didn’t replace was causing it to suck air in so no amount of flushing would matter
Old 01-23-2022, 03:02 PM #20
Yep, this right here. When I removed the reservoir for the 2nd time I found the o-ring binded and split so thats why I think air kept re-introduced itself.
I think the main cause to my problem was the old fluid being very old + the screen on the reservoir being completely blocked of crap. Never lost PS on my rig and always worked. The pump was suspicious because the excessive whining was instant and never went away when as before it was just in the cold morning and then went away.
Old 01-23-2022, 10:49 PM #21
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
@badluck You think I could flush the power steering by just using my transmission fluid exchanger and just hook a hose to the return line to the used oil. Then pump new fluid until the fluid comes clean. Then feel to the proper level?
Old 01-23-2022, 11:57 PM #22
Real Name: Patrick
Real Name: Patrick
I can’t remember your exact fluid exchange setup for transmissions. The problem that I ran into was the power steering pump flows fluid faster than I could fill the reservoir. That’s why I changed my method to 1 second engine running intervals.
Old 01-26-2022, 11:20 PM #23
So I have the pump all torn apart ready for new seals/gaskets which are coming tomorrow (Gates 348376) and upon discovery when I was eyeing the Toyota service manual instructions on pump reassembly and looking at the inscribed marks, I actually found the rotor facing the wrong way. The service manual says to have the mark facing upward when I found it facing down. Weird but here are the pictures of it all apart.
3.4L Power Steering Pump Whining Excessively-img_3139-copy-jpg  3.4L Power Steering Pump Whining Excessively-fullsizerender-copy-jpg
Old 01-28-2022, 04:39 PM #24
All fixed! Rebuilt the pump yesterday and discovered o-rings dry rotted and hard. Today I jacked up the front wheels and turned the steering wheel when it was turned off and running. Following the Toyota PSP bleed procedure and on the 2nd round, all air pockets are gone. Just now topped up the reservoir to hot line and the power steering on my truck never felt great in years!
HIGHLY recommend the Gates 348376 kit to rebuild the pump. Patience is key. I think the main cause of my problem was the reservoir screen being blocked of junk. 3 cans of brake cleaner got it clean enough.
Old 01-28-2022, 07:01 PM #25
Nicely done and congrats on getting to the bottom of your problem. Good call on sticking with your original pump and doing the rebuild.
2002 SR5 Sport 4WD
Old 01-28-2022, 10:01 PM #26
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yup good job. Glad your gates kit worked out for you..
Old 06-25-2023, 07:44 PM #27
Redcat Redcat is offline
Redcat is on a distinguished road
I
I did the flush, and while it helped, I wanted to clean the reservoir as well.
I got a used power steering pump from the local Toyota specific junkyard, and then I picked up the rebuild kit. I wanted to have a backup in case I damaged something on the pump on my truck.
The junkyard one I attempted to clean with Ballistol. Didn't really help. Had to resort to brake cleaner.
The one on the truck, I ended up using about a 1/4 to 1/2 bottle of brake cleaner. I found that if you use an air nozzle and spray air in there, you don't need to flush it with as much brake cleaner.
I'd say the flush got the power steering back to 80% and the reservoir cleaning got it the rest of the way.
Redcat is offline   Reply With QuoteReply With Quote
Old 06-25-2023, 09:34 PM #28
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I flushed several times and can see through the screen, but I still have pump noise. I am wondering if this has to do with the fluid being used to replace it.
As I have noticed in the colder months, my pump is more noisy than the warmer months. So my theory is that power steering pumps prefer toyota fluid vs. aftermarket synthetic.
As I had a pump that was very noisy. Cleaned the screen and flushed the old fluid all out, and put toyota ws fluid into the steering system. This one is perfectly quiet and functions perfectly again.
So, I am wondering if the fluid has any bearing on the noise level?
As the 02 pump on my 98 Daily driver, I know it is clean and is so much quieter now in the summer.
Am I on to something? Or just incorrect at all on this fluid as synthetic fluid is a lot thinner than toyota transmission fluid and wondering if it's effecting the noise level?
Old 06-27-2023, 12:05 AM #29
OldSilver OldSilver is offline
OldSilver is on a distinguished road
My 2000 Toyota 4Runner has around 421,000 miles and also has the original Power Steering Pump. I noticed the pump moaning around 8 or 9 months ago. It has a very slow leak. I just keep adding fluid every month or so, depending on how much I drive it. So far so good, and I have been doing this consistently since discovering it.
OldSilver is offline   Reply With QuoteReply With Quote
Old 11-15-2023, 02:34 PM #30
bob919 bob919 is offline
bob919 is on a distinguished road
Could Be Alternator Bearing Going Bad
Swore my whine was the PS pump going bad. Drove it for 4 years that way and finally decided to fix it.
Did all the things mentioned in this thread staring with the cheapest fix first: 1. flush/change the fluid and cleaned the screen in the reservoir; 2. rebuilt PS pump using the Gates rebuild kit; 3. replaced AC idler pulley; and finally 4. purchased a remanufactured PS from RockAuto. None of the "fixes" solved the problem. Whine was still there.
Finally took advice from an old mechanic friend of mine long gone: used long screwdriver and put it on the alternator and other end to my ear and sure enough, could hear it whining and "grinding". Bearings were bad.
Installed Denso remanufactured from RockAuto and whine is gone! Changed out all 3 belts while at it. Swear truck runs better now than it has in years.
So don't rule out the alternator bearings as the issue.
bob919 is offline   Reply With QuoteReply With Quote
advice , hear , power , pump , steering
Power Steering Whine FrothyLlama 4th Gen T4Rs 15 10-11-2020 03:02 PM
Engine Whine - mechanic wants to replace my power steering pump at 70k miles Mike2005v8 Maintenance/Detailing 7 05-02-2017 11:48 AM
Power steering pump V8 whine-rebuild rjb75 4th Gen T4Rs 6 04-10-2017 09:16 PM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
