Old 11-15-2023, 06:14 PM #31
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by bob919 View Post
Swore my whine was the PS pump going bad. Drove it for 4 years that way and finally decided to fix it.
Did all the things mentioned in this thread staring with the cheapest fix first: 1. flush/change the fluid and cleaned the screen in the reservoir; 2. rebuilt PS pump using the Gates rebuild kit; 3. replaced AC idler pulley; and finally 4. purchased a remanufactured PS from RockAuto. None of the "fixes" solved the problem. Whine was still there.
Finally took advice from an old mechanic friend of mine long gone: used long screwdriver and put it on the alternator and other end to my ear and sure enough, could hear it whining and "grinding". Bearings were bad.
Installed Denso remanufactured from RockAuto and whine is gone! Changed out all 3 belts while at it. Swear truck runs better now than it has in years.
So don't rule out the alternator bearings as the issue.
Another example why diagnosing the problem before throwing parts at it is important.
Old 11-15-2023, 08:20 PM #32
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Also another example that guys should invest in a mechanic's stethoscope. The screwdriver trick works, but I like the stethoscope better. I had a pulley noise I had to deal with not too long ago and I was quickly able to diagnose it was the alternator pulley bearing with my stethoscope. This is a tool every DIY Mechanic should own.
Here's the one I own:
Amazon.com
Old 11-21-2023, 04:57 PM #33
bob919 bob919 is offline
bob919 is on a distinguished road
Learn From Mistakes
For the record, my mechanic had said he thought the whine was coming from the PS pump after I got some other work done on it so that's why I focused on it.
I was also trying to go from the cheapest fix to the most expensive fix.
Looking back, I would not have spent my time and effort flushing and then rebuilding my old PS pump - I would have flushed and put a remanufactured pump on in one swoop. Tim's great video of flushing and cleaning the screens solved his problem so I thought I would see if I could get out that easily (and cheap) also.
Even though it wasn't the problem, replacing my old one with the remanufactured one (and a flush) did result in better handling as it seems the steering is more responsive. IMHO.
But I understand if someone wants to rebuild their own. That's their choice.
So that's why I posted, so others could learn from my mistake(s).....and my mechanic's original misdiagnosis.
bob919 is offline   Reply With QuoteReply With Quote
Old 11-21-2023, 05:06 PM #34
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
For the record, my mechanic had said he thought the whine was coming from the PS pump after I got some other work done on it.
So that's why I posted, so others could learn from my mistake(s).....and his misdiagnosis.
Sounds like your "Mechanic" should invest in a mechanic's stethoscope as well.
Old 07-17-2024, 04:20 PM #35
jhams jhams is offline
Real Name: jakobi
jhams is on a distinguished road
Real Name: jakobi
me too bro idk what to do
jhams is offline   Reply With QuoteReply With Quote
Old 07-17-2024, 06:54 PM #36
prybar's Avatar
prybar prybar is online now
prybar is on a distinguished road
prybar's Avatar
you could start by reading this thread to find out how he resolved the issue..?
'99 Limited, 260k
prybar is online now   Reply With QuoteReply With Quote
advice , hear , power , pump , steering
Power Steering Whine FrothyLlama 4th Gen T4Rs 15 10-11-2020 03:02 PM
Engine Whine - mechanic wants to replace my power steering pump at 70k miles Mike2005v8 Maintenance/Detailing 7 05-02-2017 11:48 AM
Power steering pump V8 whine-rebuild rjb75 4th Gen T4Rs 6 04-10-2017 09:16 PM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
