Old 11-20-2023, 05:15 PM #1
gtojimbo's Avatar
gtojimbo gtojimbo is offline
Real Name: jim
gtojimbo is on a distinguished road
gtojimbo's Avatar
Real Name: jim
starter wouldnt quit running
this morning i jumped in my 4runner, turned the key to start the engine and the starter wouldnt quit! i twisted the key back and forth several times and the starter wouldnt shut off! i put the tranny in nuetral, (manual) popped the hood and was scrambling to find a wrench to disconnect the battery and just as i got to the battery with a wrench, it stopped. it scared the hell out of me, mostly because it was surprising.
i'm guessing a stuck starter solenoid--it doesnt look like new starters are available anymore what would my best replacement be? i would appreciate suggestions--thankyou
99 sr5 manual 4 wheel drive
gtojimbo is offline   Reply With QuoteReply With Quote
Old 11-20-2023, 05:28 PM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Sounds like a sticking plunger to me. Denso 280-0167 would be the direct replacement (1.4kw) but you can also use Denso 280-0166 (1.8kw). The Denso 280-0166 is larger dimensionally. You could also rebuild your current starter.
Old 11-20-2023, 05:35 PM #3
gtojimbo's Avatar
Real Name: jim
gtojimbo's Avatar
Real Name: jim
do you think rebuilding the original one is better than buying another one?
Old 11-20-2023, 05:57 PM #4
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
I'll second @Bad Luck 's thoughts Contacts welded together.
New Plunger and contact kit would be first thought as long as starter wasn't making odd noises acting normal.
Got almost 400k mi doing this twice bearings never changed, died in a crash.
Old 11-20-2023, 06:22 PM #5
Real Name: Patrick
Real Name: Patrick
If the current starter is OEM/Denso then I would rebuild it. If it's aftermarket (not OEM/Denso) then I would replace it.
Old 11-20-2023, 06:52 PM #6
Seconded. And by 'rebuild' we mean new contacts and plunger. It is quite easy.
The first time my starter failed it stuck on like this. Most recent failure (around 300k miles) was long wait before engagement of the starter or multiple tries to get the starter to engage.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 11-20-2023, 08:26 PM #7
gtojimbo's Avatar
Real Name: jim
gtojimbo's Avatar
Real Name: jim
wow, thanks for the input! my starter is original and the reason i asked is i've heard the ones from autozone arent too good. yotashop.com makes a point of theirs being rebuilt by denso too original factory specs and i thought it might be better.
Old 11-21-2023, 12:28 AM #8
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Same thing happened to me. The plunger got stuck against the copper contacts. Rebuild the solenoid with new contacts and plunger and carry on.
I've got a video for the job.
Old 11-21-2023, 02:31 AM #9
gtojimbo's Avatar
Real Name: jim
gtojimbo's Avatar
Real Name: jim
great video--thats what i'm going to do,thx
Old 11-21-2023, 08:19 AM #10
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
Is there an aftermarket remote start? I had a similar failure due to that failing.
thennen is offline   Reply With QuoteReply With Quote
battery , key , quit , starter , wrench
Wouldnt smog and how I beat the system KaliKid 3rd gen T4Rs 7 02-27-2016 04:09 PM
Does 5th gen have starter protection to prevent start when running? wxxiong 5th gen T4Rs 3 11-18-2014 02:53 PM
Rear left wheel wouldnt spin ohdaho Problems & Warranty Issues 6 01-22-2011 01:22 PM
wouldnt this be nice to bring home? 4Runner8 5th gen T4Rs 5 07-23-2010 12:35 PM
Starter Won't Quit T4RBoarder 3rd gen T4Rs 1 11-08-2007 06:43 PM
