01-21-2022, 05:09 PM
What is this part?
I had my skid plates off today and I found this sitting on my front skid plate. It's a little over 1" square and says "N018" at the bottom. Any ideas what it is?
1997 SR5, 3.4L, Manual
01-21-2022, 05:31 PM
I believe that's part of the system that fastens the lower valence of the front bumper to the upper metal portion. Look where the lower valance bolts on to the upper part and you should see that there are 5 or six screws going through into the metal portion. Those screws go through the part pictured.
edit: I was thinking of part 90179-06127, which this is not...
‘98 T100 SR5 4X4 5spd (sold)
‘99 4Runner SR5 4x4 5spd E-Locker Unicorn
01-21-2022, 05:37 PM
I did some googling and it looks like maybe it's a body shim?
01-21-2022, 05:52 PM
Real Name: Evan
Real Name: Evan
Looks like the shim for the brake line on the spindle to me.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
01-21-2022, 06:17 PM
It's like 1/8" thick. I think the shims you're talking about are those thin sheet metal ones?
01-21-2022, 06:23 PM
Real Name: Evan
Real Name: Evan
Yeah they’re thin and have a lip on one side.
01-21-2022, 07:10 PM
Real Name: Devan
Real Name: Devan
+1 for brake shim
01-21-2022, 07:48 PM
Originally Posted by Devbot
+1 for brake shim
It's not the brake line retainer clip. Similar shape but the retainer clips are thin and flexible. This is thick and rigid. Plus I just checked and both of my retainer clips are in place.
01-21-2022, 07:52 PM
Real Name: Devan
Real Name: Devan
Oh my bad I missed the 1/8in thick part. Welp that's all I got, that's the only thing I've ever seen that's the same shape
01-21-2022, 08:24 PM
Specialty Products Company 47183 1/8" Camber/Caster Shim
https://www.summitracing.com/parts/sps-47183
2000 SR5 Sport - 4EAT and E-locker, King 2.5s, EimKeith PCK, SPC UCAs, 33" KO2s on Black Rhino Boxer gloss gold 17x8.5, Savage/Lotus skids, 4xInnovations front bumper/sliders, Shrockworks bumper & tire carrier, Lil Skip Gas Tank Skid, Magnaflow Overland cat back
01-21-2022, 08:34 PM
Originally Posted by Twan
Well done sir! I just had an alignment done last week so it doesn't give me warm fuzzies that it was just chillin in my skid plate.
01-21-2022, 08:39 PM
Well, those aren't used on a 4Runner... they are for old-school muscle cars and similar. So at least YOUR truck isn't missing anything...
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-21-2022, 08:48 PM
Yeah, just called the shop and confirmed. He said the 4runners don't use shims and also said that body shops sometimes use them as body shims. I had body work done like 2 years ago so maybe it fell out of a fender or something.
01-21-2022, 10:28 PM
I'm late to the party, but this is likely the case. Probably no big deal as long as all your stuff is still lined up.
The 4Runner Show
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
