01-26-2022, 06:47 PM
#31
Originally Posted by octanejunkie
Did you do the door stickers under or nah because of the liner?
Sent from my Pixel 4 XL using Tapatalk
From what I remember you really do need those sticker pads because the metal clips slide right on the door and would damage the paint for sure. The stickers are really thick. I can find all the flare pieces/clips I took off and take pics if you want. I took that flare off because I could never find the discontinued mud guards for it and it sprays dirt up the side to an insane level without the running boards. It might be ok with the 3D printed caps I guess. I put the base model mud guards on with zero flare but my new tires rub on them sometimes.
99 SR5 v6 4WD
11 SR5 v6 4WD
01-26-2022, 06:54 PM
#32
Originally Posted by mymalade
Looking forward to those pictures. When you get the flares, can you tell me if they already have a rubber gasket installed? Also where did you find them, and is the seller sending the hardware as well?
Mine was missing the rubber from day 1, and the fender paint shows it. Looking at pics of ones for sale just now they don't seem to have it. When I searched that PN it came up as a Tacoma part. Looks like it works on the 4runner too though.
99 SR5 v6 4WD
11 SR5 v6 4WD
01-26-2022, 09:13 PM
#33
The black flares never had any trim on the outer lip. Only the Limited and wide-SR5 (painted, same width as Limited) flares had the rubber trim.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
01-27-2022, 12:41 PM
#34
Originally Posted by phattyduck
the black flares never had any trim on the outer lip. Only the limited and wide-sr5 (painted, same width as limited) flares had the rubber trim.
-charlie
Yep - 99 SR5
1999 "Highlander" V6 4WD E-Locker || TRD Supercharger, URD 7th Injector, 2.2 Pulley || Toytec Aluma Series Boss Suspension, SPC A-Arms, Durobumps, Overland Endlinks || B&M Trans Cooler || 231mm Tundra Brakes, SS Brake Lines || 17" TRD Pro Wheels || BFG KO2 265/70R17-C || TRD Exhaust || 01-02 Tail Lights || Original Owner
01-27-2022, 12:52 PM
#35
I realize this is probably ridiculous on my part, but if I can't add fender flares, I don't want to buy this 4Runner that I have been eyeing. For some reason I think the fender flares completely make the truck look a thousand times better, and I hate the look of no flares. I have always been under the impression that it was pretty easy to add the black flares to a base model, but I was just digging around the forum and it seems like I might have to drill holes and that the hardware is hard to find. Can anyone confirm?
Have you considered these:
1999 Toyota 4Runner Bushwacker Extend A Fender Flares | RealTruck
01-27-2022, 02:13 PM
#36
Here's how mine currently is. 3D printed short caps, Rally Armor universal mud flaps (normal size, but I'd like the 'long' size they used to make):
01-28-2022, 09:04 PM
#37
Another pic inside the rear wheel well:
The metal fender lines up with the line just outside where the bolts are inside the fender.
01-29-2022, 12:18 AM
#38
Thanks for the details and for the photos, now I just need to find a decent set of those flares. I think I can handle putting holes in the wheel well underneath. I'm still uncertain how the little door pieces get held on but I'll figure it out
01-29-2022, 12:47 AM
#39
Real Name: GundamDeathscythe
I consider myself lucky for finding a 98 Limited in May 2021. Not knowing anything and not wanting a Limited until I found out it had a factory working locker.
I'm just missing the front bumper flares. The whole bumper actually is from another non flared 4runner. its all good though. I originally was window shopping for a beater S10 or Ranger 4x4. both open diffs.
01-29-2022, 02:01 AM
#40
Real Name: C8H18 Mike
There are clips that clip onto the door lip with screw bosses at 90° that the flare trim screws onto. If these don't come with the flares that you find/buy you will have to haunt junkyards till you find 8 of them; 4 per door.
1999 Toyota 4Runner SR5 Un-Sported 2WD, V6 Auto -> 2WD 4runner Journal Thread
01-29-2022, 11:36 AM
#41
Here's the hardware for the SR5 flares, I found this on an old thread when helping out a friend get a set mounted up. The door clips/screws are in box #1. The clips fit over edge of door, providing screw holes for flares to be mounted. Boxes #2 and 5 are for rear flares, but machine screws/nuts can also be used.
01-29-2022, 07:42 PM
#42
Damn, now that is some extremely detailed information and is extremely helpful. Thanks for that, now I know what to look for if I can ever find a set of flares.
02-13-2022, 12:51 PM
#43
I promise this will be my last question in this thread. In the photo above, does anybody know what the little eclipse are in box number 5? Where do they go? I actually saw a set of these flares in the junkyard, and there weren't any of those clips on the rear flares and it didn't look like they had ever been removed previously.
02-14-2022, 01:24 PM
#44
I have 2 trucks with these flares, both used different mounting hardware. Depending on what your truck came with originally you might need to use alternative mounting hardware, like I had to on my SR5 base model.
I used these for the rear flares since the "stock bolts" were much bigger than the grommet inserts in my fenders
Amazon.com: Mtsooning 20 Pcs/Set Universal Car Auto 4.8x19mm Self-Tapping Screws Captive Loose Washer 8mm Hex Head Black Hot C45 : Industrial & Scientific
I wanted something with a large, captive washer that would fit snugly into the plastic grommets, and they worked great!
