Old 01-23-2022, 07:35 PM #1
superhomunculus's Avatar
superhomunculus superhomunculus is offline
superhomunculus is on a distinguished road
Finally picked up my new welder aaaand it doesn't work
I picked up a Hobart 210 this weekend and was trying feed the wire today. Turned it on, fan kicks on but when I pulled the trigger it just clicks. I can't call customer service until tomorrow, so I am just seeing if anyone has any suggestions in the meantime.
superhomunculus is offline   Reply With QuoteReply With Quote
Old 01-23-2022, 08:11 PM #2
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
I barely have a working understanding of welders, but check the feed assembly ~ take the tension off Completely, pull the trigger to make sure the drive is working. If the drive is working, then make sure you have the feed roller in the right place for the wire you have (solid vs flux core and Maybe size of wire), then set the tension correctly and try again.
Brian. is offline   Reply With QuoteReply With Quote
Old 01-23-2022, 10:44 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Will wire feed through it? The mig wire has to pulled through the gun to work. Mostly you can hear the wire motor when you pull the trigger.
Old 01-23-2022, 10:48 PM #4
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
with my new hobart multi handler before christmass, received home not working (everything but actually welding worked)
I had to open up the box and access where the ''montherboard'' is located, and there was a 3 prong, small white connector that was disconnected from factory. Plugged it and closed up the box, then built a new trailer
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 01-24-2022, 07:24 AM #5
I pushed the wire a few inches into the beginning of the welding gun line to get it started, I didn't feed it all the way to the trigger. The wire motor doesn't do anything. I just hear a click when I squeeze the trigger. Does it need it fed to the trigger? The directions weren't real clear. Ill get me some coffee and take another look at at this morning before a call. Thanks kind sir!
Old 01-24-2022, 07:28 AM #6
[QUOTE=diverscale;3706210]with my new hobart multi handler before christmass, received home not working (everything but actually welding worked)
I had to open up the box and access where the ''montherboard'' is located, and there was a 3 prong, small white connector that was disconnected from factory. Plugged it and closed up the box, then built a new trailer[/QUOT
I read something about that on a couple of other forums. I might check that out before I call later. Thanks
Old 01-24-2022, 09:05 AM #7
LOL, I needed coffee. I had the switch on spool gun instead of mig gun.
Old 01-24-2022, 09:06 AM #8
Thereel69 Thereel69 is offline
Thereel69 is on a distinguished road
Dope!
Thereel69 is offline   Reply With QuoteReply With Quote
Old 01-24-2022, 09:56 AM #9
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Ah.. At least you got it working...
Old 01-26-2022, 05:56 PM #10
Romeo1's Avatar
Romeo1 Romeo1 is offline
Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice Romeo1 is just really nice
Romeo1's Avatar
That’s not too bad I guess….. there’s always worse right? Worked with the guy once that destroyed every single consumable we had For our millermatic While we left him alone at the shop for a service call. Apparently shielding gas was not something he quite understood. The best part though was when the boss made him regrind everything smooth and before I actually welded the second time.
That guy was something else, I mean it was a small town Ag shop, he was a new guy, and I think he just thought all you did was pull the trigger. None of us ever quizzed him to see if he actually knew what the hell he was doing. Lol.
99’ Black “Highlander” sport, oak, 5VZ auto, 4.30 axle, e-lock, 265/75 Grabber X3,, Bilstein 6112 (2”) front 5160 rear shocks, OME 2906 springs, Durobumps, 4x Inovations front middle rear skid plates, 4XI square TRD tube sliders, lil skips tank skid, lotus dev RCA skids, overland custom sway bar links, Amp’d hidden winch, warn Vr Evo 10s
Romeo1 is offline   Reply With QuoteReply With Quote
Old 01-26-2022, 07:24 PM #11
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
I bought a used Millermatic 140 off a Marine here locally a few years ago that had it set up for solid wire and no gas, and had been welding on his Harley with it. Had the solid wire drive roller in the feeder the and a roll of solid wire in the machine, and was missing the gas nozzle just like flux core would be set up. I tried hinting before I bought it that it’s not a good idea to run it like that, but he was cocky and did not give a flying f*ck about my input. I wonder if that dude is still alive! His bike provably fell apart doing freeway speeds. There’s a reason flux cored wire exists!
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 09-19-2022, 09:04 PM #12
ungoods ungoods is offline
ungoods is on a distinguished road
yepp
ungoods is offline   Reply With QuoteReply With Quote
Old 09-19-2022, 09:06 PM #13
any updates?
Old 09-20-2022, 10:57 AM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
I don't care for Flux core myself. I know lots of folks swear by it for rusty metal. However, I don't care for it as the splatter is 10x worse. Welds don't seem to be as good. I like the sound of welding with shield gas as I can tell by the sound how the weld is doing. Being you don't want oxygen at your weld point to begin with, I just don't see the need myself. That's just me though...
Old 10-28-2022, 08:42 AM #15
ManOnTarget ManOnTarget is offline
ManOnTarget is on a distinguished road
I love my Hobart 210. When I got it the solo kid in the back for the gas was wired wrong so I wasn’t getting any gas. Took a couple hours to figure that out then she worked like a charm!
ManOnTarget is offline   Reply With QuoteReply With Quote
call , clicks , finally , picked , trigger
Lefty loosey righty tighty doesn't work doesn't work on Antenna. Nachies 5th gen T4Rs 21 10-15-2022 01:52 AM
I am no welder but this doesn't look right...LOL superhomunculus 3rd gen T4Rs 20 12-29-2021 02:53 PM
Finally picked up a 3rd gen! Whitey0817 3rd gen T4Rs 3 09-27-2014 06:45 PM
Cruise Control light doesn't come on and Cruise doesn't work. CZ Eddie 3rd gen T4Rs 8 12-15-2012 08:09 PM
Finally picked it up Hot Rod 4th Gen T4Rs 2 06-19-2005 11:16 AM
