Old 01-27-2022, 12:50 AM #16
fatherohenry's Avatar
fatherohenry fatherohenry is offline
Real Name: Mark KN6TZI
fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough fatherohenry is a jewel in the rough
Originally Posted by 3bears View Post
My rear seat has the worst stains, from a little kid with previous owner
The kid had a previous owner? Hope you got a good deal on it!
'96 T4R SR5 | 4WD | Auto | 199 TBU | 262k+
fatherohenry is offline   Reply With QuoteReply With Quote
Old 01-27-2022, 11:29 AM #17
MTRunner00 MTRunner00 is offline
Real Name: Brad
MTRunner00 is on a distinguished road
Real Name: Brad
Originally Posted by pluton View Post
I washed the OEM covers from my earlier Toyota truck. I didn't trust that they would survive the top load washers that we had, so I washed them in the bathtub, then air dried.
IMO, the problem with wash-in-place solutions is that a certain amount of whatever concoctions you use to clean them will remain inside the seat. I wanted them clean, not chemicalized.
For Reference OP, I sprayed upholstery cleaner on the covers while installed on the seats, then used my shopvac to remove the cleaner off the seat.
Now the seats have the cleaner smell embedded in them. It is a strong annoying smell.
I would NOT recommend cleaning the covers on the seat. Remove them and clean them in the bathtub as shown above.
2000 SR5 Sport 4WD, A/T, E-Locker, 285k, no lift, 265/75/16'S
Mods- ISR, Deckplate, Ultra Gauge, Spiker Mount
Gave up on making it nice.
SAS coming up
FJB
MTRunner00 is offline   Reply With QuoteReply With Quote
Old 01-27-2022, 11:42 AM #18
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all Brian. is a name known to all
Brian.'s Avatar
Well.. right tool for the job, and a shopvac isn't that in this situation. Spend the $30 to rent a carpet cleaner WITH the upholstery attachment (little handheld suction). Then just hot water and suction will pull all the junk out of the fabric, including the remaining upholstery cleaner that the shopvac stood no chance at removing.
I've done it to several vehicles, seats and carpet, with a carpet cleaner I own and there is Never a smell left behind, or other negative issues. It works. Maybe it's not the best overall solution, but it's cheap, fast and easy to get 90% of the way there.
Brian. is offline   Reply With QuoteReply With Quote
Old 01-27-2022, 11:49 AM #19
Real Name: Brad
Real Name: Brad
Yes Agreed. You learn by Blood or Money. In my case it will be by Money. I will rent one of those and try to remove my mistake.
SAS coming up
FJB
Old 01-30-2022, 06:45 PM #20
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
I recently cleaned the lower seat cushions front & rear as well as the rear carpet and used a spray on foaming fabric cleaner from Chemical Guys with a fabric cleaning brush attached to my Dewalt drill.
After using the brush attachment on the seat I used clean microfiber towels and removed the foam and dried the area cleaned.
Repeated the process 2x in areas that were more heavily soiled/stained.
Very satisfied with results.
Seat cleaning-ca775837-26ec-40c1-bcf5-e483f2280f1f-jpg  Seat cleaning-005c5894-a2a8-4bd5-be87-90fa62770153-jpg
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 02-16-2022, 12:17 PM #21
DenisDinkledj08 DenisDinkledj08 is offline
Banned
DenisDinkledj08 is on a distinguished road
Banned
The cleaning of car seats is, at first glance, a completely uncomplicated process. However, it turns out that the seats must first be dismantled, then clean all their surfaces, for example, with a soapy solution, and then proceed to clean with special agents. If a non-professional takes on the job, he will have to spend several hours. For this reason, cars are sent to dry cleaning. It is faster and, in some cases, cheaper. I tried a couple of times to clean it myself but concluded that it's better to give the professionals from emop and they will do much better. But it's an amazing experience, and you should definitely give it a try.
DenisDinkledj08 is offline   Reply With QuoteReply With Quote
Old 02-16-2022, 01:28 PM #22
DAW89446's Avatar
DAW89446 DAW89446 is offline
Real Name: Dave
DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light DAW89446 is a glorious beacon of light
DAW89446's Avatar
Real Name: Dave
Originally Posted by octanejunkie View Post
I'm looking to "deep clean" my seats, mostly the cusions, and was wondering
1. Spot Clean, and if so, what method?
2. Remove seat covers and throw them in the wash (or dishwasher)
What have you all done?
I've seen a few youtube videos that look easy, but it never really is lol
EDIT: cloth seats. Sry
Today I have an ‘18 SR5, but before that I had an ‘02 Tacoma TRD, likely the very same seats.
What I did was simply take my upright Hoover carpet shampooer with upholstery kit and go at the carpets, seats and dash mat annually. Worked just fine. The few times I got a small stain, I’d just use one of the canned carpet shampoo products and a wet washrag.
Dave
2018 4Runner SR5
2012 Subaru Outback Premium
DAW89446 is offline   Reply With QuoteReply With Quote
clean , dishwasher , remove , seat , wash
How does the plastic seat shield that holds the power seat buttons attach? Capnemo 3rd gen T4Rs 11 08-24-2021 09:54 PM
SOLD: 96-00 4runner seat track covers and seat parts, moon mist, $25, SF Bay Area, rglsr For Sale: T4R Items 2 07-16-2020 08:49 AM
Bypass seat airbag and seat belt lights? Recaro install steve germany 4th Gen T4Rs 0 04-04-2009 09:18 AM
urbanrunner seat cleaning??? 08UrbanRunner08 Maintenance/Detailing 4 11-05-2008 02:08 PM
