Old 01-27-2022, 03:38 PM #1
judoant's Avatar
judoant judoant is offline
judoant is on a distinguished road
judoant's Avatar
front wheel bearing replacement
I had a low rumble while driving and when I jacked up the front driver wheel and grabbed the tire at 12 and 6 it would rock a little. I pulled the spindle and took it to a shop to press out the bearing and they said they could not even get the hub out. They have a 20 ton press and he said they bent 1/2 steel plates trying to get it out.
I have taken it to another shop to have the same thing done today. If they also fail what is my next best option? Find a junk yard spindle and call it a day? Try to return my almost $200 in bearing and seal or keep it?
99 4 Runner Limited. 3" Toytec Ultimate lift with SuperFlex rear coils. 231mm Tundra calipers. Rear diff breather extension. 285/75-16 Nitto Trail Grapplers. Savage full skids & sliders w/ kickout. ISR mod. LED gauges. Shrockworks front plate bumper w/ loop. 4xInnovations rear plate bumper.
judoant is offline   Reply With QuoteReply With Quote
Old 01-27-2022, 07:21 PM #2
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
I have a part list at home I can post when I get to said home.
My plan was to convert the front to manual hubs when I needed to do the bearings. Perfect time to do it if you ask me
Oops, sorry I misread that because for some reason on mobile this giant video keeps loading over the first post... I was basically refreshing and trying to read what I could before the video popped up.
But okay yeah that is really weird that it won't press out
Old 01-27-2022, 07:47 PM #3
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Toyota wants me to upgrade to their new 2021 Venza.... Not in this market!
As for the spindle, yeah I would recommend getting a junkyard unit and "rebuild" it with new bearings and hub. Just make sure the spindle you buy at the yard is in great shape with the smallest amount of rust as possible.
front wheel bearing replacement-screen-shot-2022-01-27-6-39-17-pm-jpg
2000 4Runner Limited 4x4 V6
Old 01-27-2022, 08:03 PM #4
judoant's Avatar
judoant's Avatar
So the second place got it out. Charged me $240. We’re gonna have a conversation about the bill. I was expecting like $100
Old 01-27-2022, 09:43 PM #5
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
if you want to know what is involved I show the process in this vid
pressing the bearing out is not hard but takes time and know how. obviously the first shop did not take the snap ring out and just hammered away on it? not great.
unless you had a $100 pre-defined arrangement? I would say $240 is a pretty fair price to remove the old spindle, clean, inspect and re-press the new bearing. if you don't have the tools yourself?
Old 01-28-2022, 12:54 AM #6
clearock clearock is offline
clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice clearock is just really nice
The snap ring is under the wheel wheel hub and requires the said to be pressed out before the snap ring is removed and the bearing pressed out. Special attain needs to be paid not to bend the backing plate all to s&^%. I agree the work involved to replace the wheel bearing is well worth 240 especially if things r rusted and require extra attain, I would not touch the job for 100.
clearock is offline   Reply With QuoteReply With Quote
Old 01-28-2022, 08:05 AM #7
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
$100 for the work is just insulting. What they're shooting you in absolutely fair.
Would YOU have done all this for only $100?
bearing , front , press , shop , wheel
Front Wheel Bearing Replacement mtbtim 3rd gen T4Rs 37 08-15-2021 08:58 PM
4x4 Front Wheel Bearing Replacement Asmara 4th Gen T4Rs 4 02-09-2016 05:39 PM
4th Gen 2wd front wheel bearing replacement phil123 4th Gen T4Rs 12 12-24-2013 10:10 AM
Front Wheel Bearing Replacement gstai 3rd gen T4Rs 8 11-18-2012 04:34 AM
front wheel bearing replacement Forrrrest 3rd gen T4Rs 2 11-03-2012 06:38 PM
